Old 11-13-2006, 11:36 PM   #1
Unhappy
Filling a Large Tub
I will be installing a large soaker tub (72"x36", 46 gallons). I am wondering if there are faucets that will fill the tub faster or am I constrained by the 1/2" pipe?
Would it make sense to run a direct line from the basement in 3/4" pipe? The water main is 3/4" and branches off to 1/2" throughout the house.
Blaze25 is offline   Reply With Quote
Old 11-14-2006, 06:29 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Filling a Large Tub
Most of the soaker tub valves I've installed are 1/2" inlets, you could pipe 3/4" to the tub and reduce at the inlets.
Get a roman tub valve, they do a good job on filling these tubs, 46 gallons to fill, hope you have a good sized water heater, 65 to 80 gal.
Ron The Plumber is offline   Reply With Quote
Old 11-14-2006, 07:23 AM   #3
Filling a Large Tub
Ron,
Thanks for the feddback!
I just had a 75 gallon power vented water heater installed as I have been through the experience of having a large tub with a small heater...it wasn't fun.
Plans for a garage loft (large set of shelving) paul_2 Carpentry 10 08-16-2010 08:06 PM
What do you use to reconnect a large gauge wire that was cut? bonedoc Electrical 9 08-10-2007 10:52 PM
going from 220 large wire to 220 small? bonedoc Electrical 7 08-06-2007 11:17 PM
