Fill In Old Clean Out - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-08-2012, 11:49 PM   #1
Fill in old clean out
So, I decided to turn my garage into an addition of my house. However, the problem is that there was a clean out for the sewage system in the garage. I've put in a new clean out outside (not very far away from the old one) and it seems to work great. (As we've had clogs several times since then due to the kiddos flushing various items down the toilet.) Now, how do i cap off the old one to make sure if we have another overflow it wont flood the new room? Can I get some kind of flat cap and seal so it wont leak there? Help would be appreciated. I don't want to get flooring till I'm sure no water will come from this old clean out!
amylou2215 is offline   Reply With Quote
Old 01-08-2012, 11:59 PM   #2
jproffer's Avatar
Rewards Points: 706
You could cut it off flush and put a test plug into it.
They do make PVC plugs, depending on the size of the pipe....but it would still have a "head" on it that would sit above the floor.
I don't suppose you're willing to bust a little concrete??
No?
OK, well a test plug might be your best option...but no matter what, something is going to be above the floor a little bit.
jproffer is offline   Reply With Quote
Old 01-09-2012, 12:54 AM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Do you have a picture of it so we can get an idea of how its plumbed?
plummen is offline   Reply With Quote
Old 01-09-2012, 08:26 AM   #4
I'll take a pic when I get home from work. But it's not threaded, the cap just sits in almost flush with the floor. I wouldn't mind terribly if is barely above the floor when I'm done, as I'm probably putting carpet down. My main concern is I want to make sure it doesn't leak in case we have problems again! I'd rather not bust out concrete if I can help it. Then we'd be getting into stuff this little ole gal can't do!
Old 01-09-2012, 09:33 AM   #5
get a "dollar plug". At least that is what we call them around here. It is a plug that has a rubber gasket with a nut and bolt and as you tighten the bolt the gasket expands to seal off the pipe. They come in different sizes, so you will have to get the right size. When I have to do something like you are describing, I can usually cut part of the plug off, so it can slide into the pipe a couple of inches, then you can pour a little concrete in the pipe above the plug.
broox is offline   Reply With Quote
Old 01-09-2012, 09:34 AM   #6
MarginallyQualified
Rewards Points: 2,464
Originally Posted by amylou2215 View Post
...it's not threaded, the cap just sits in almost flush with the floor ...
OK. The fix is rather straightforward...
Oh well. The proper fix will include breaking up the floor some.
The end of the pipe needs a threaded fitting that a plug can go in to.
When all is done that should be no higher than the finished floor level.
Lower than finished is fine and probably better for your new use.
Depending on what exists now... is how deep you'll have to dig to fix things.
hth
Old 01-09-2012, 07:27 PM   #7
Thanks for some great thoughts! At least I know which direction I'm headed. Now I need to decide when I'm ready to bust out the concrete!
Tags
clean out , remove
To fill, or not to fill? IRuehl Landscaping & Lawn Care 7 08-27-2011 05:30 PM
toilet fill valve? Roundeye Plumbing 11 07-26-2011 02:17 PM
Leaking Fill valve tallman Plumbing 1 07-14-2011 02:01 PM
How to seal and fill sap veins before painting. fritzycat1 Painting 6 10-21-2009 12:13 AM
Slow toilet tank fill even with NEW fill valve? Zilla Plumbing 8 08-10-2009 10:37 PM
