Fil-Trol Expansion Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-19-2012, 02:34 PM   #1
Rewards Points: 275
Fil-Trol expansion tank
My new pressure relief valve leaks a little heating system water after the boiler shuts down. Now I am suspecting that the Fil-Trol expansion tank could be causing it. It's a model 110 tank & is pre charged for 12 psi with a max working pressure of 75 psi. I put an tire pressure gauge on the air valve & it reads 25 psi. Is the expansion tank causing my problem? How do I check it. If the tank is good & the relief valve which is brand new are ok, where else do I look.
Also, I'm thinking I should remove the pressure relief valve & install a water pressure gauge, run the system & see what the water pressure is. If it climbs to over 30psi, where can I look beside the expansion tank. Thanks for the help, please.
maddog1 is offline   Reply With Quote
Old 12-19-2012, 04:05 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,404
WtF,... Why another thread,..?? This leads to confusion,...
This is ALL the SAME Problem man....
The Following User Says Thank You to Bondo For This Useful Post:
maddog1 (12-19-2012)
Old 12-19-2012, 04:58 PM   #3
Rewards Points: 275
Bond- Yes your right. I did not mean to make things confusing with two threads on the same thing. My bad. I'm going to look at the gauge & post back to you on the other thread. Sorry for my error here. Guess I hit the panic button.
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 05:55 AM
Exterior expansion tank location jeffnc Plumbing 2 12-04-2012 06:49 AM
Question re draining heating expansion tank Rav HVAC 4 11-19-2012 09:53 AM
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 09:29 AM
Installing an expansion tank Homerepairguy Plumbing 1 01-25-2011 08:10 AM
