Fibreglass Bathtub Leaks Need Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2010, 09:08 AM   #1
Hey Guys,
I'm having an some trouble with a fibreglass bathtub,
it has been corked [mastic] many times, but after a few weeks the water starts coming through where the mastic joins the bathtub and wall and leaking downstairs.
The leak mainly starts from where the two walls meet [but around the frame of the bathtub]
I have also put up some images
http://www.flickr.com/photos/47147186@N03/
I think it might be cause the bathtub moves [the fibreglass bathtub is quite thin]
Does anyone know of some way of creatively / cost effectively fix the problem?
Any advice would be appreciated.
C
cookerz is offline   Reply With Quote
Old 02-02-2010, 09:37 AM   #2
Remodeling Contractor
remove all the old caulking. clean well with denatured alcohol and then apply a bead of silicone caulking.
Old 02-02-2010, 11:29 AM   #3
It has been sealed many times, and each time the water eventually starts leaking again.
The most recent one that was used was "Durabond Lexel Super Elastic Sealant" but after a few days that started leaking too !
Old 02-02-2010, 11:36 AM   #4
are you sure that is where the leak is coming from. You should be able to seal it fine if the material is first cleaned and the caulking is applied and tooled.
Old 02-02-2010, 11:39 AM   #5
going to be hard to seal until wall behind panels are dry. does tub flex/move when you step into it?
Old 02-02-2010, 12:40 PM   #6
Household Handyman
Rewards Points: 1,408
From experience: Let's say the leak(s) are at the point where the walls meet (corners), and where the panels meet the tub. First we must remove all old caulking/sealants. These areas need to be cleaned with isopropol alcohol. Then these areas need to be allowed to dry for a minimum of 24 hours in a well ventilated bath area. The use of a small fan and a space heater for warm air helps here. Be careful with the heater in a bath area. This is a debatable issue, but I use it: Place water in the tub approximately one-half full. This may slightly open the cracks between the tub ledge and lower panel edges. Use a good "Tub and Shower Surround" type caulking. I like to use a small bead first and "strike it" (push it into the seams) with a damp finger. After the first layer of sealant has been applied, and allowed to dry for maybe 1/2 hour, I run a little wider bead-again striking it for a smooth finish. Allow the sealant to cure a couple of hours before emptying the tub and using the shower, the longer the better on the shower part. Good Luck, David
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 6 02-15-2010 10:24 AM
Bathtub Spout Leaks Behind Spout (pics) wallix Plumbing 7 10-14-2008 03:41 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 05:45 AM
Scratches in Fibreglass Bathtub SarahAnn General DIY Discussions 6 10-19-2006 08:27 PM
