Fiberglass Water Tank Repair - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-18-2011, 03:03 PM   #1
I have a fiberglass bladder pressure tank at my water well. When I primed it, I noticed a small leak between the tank and the collar at the top where the air valve is. A little water and air were hissing out at a very slow speed. Could this be causing me to lose pressure on the tank? If so, can it be repaired?
Thanks -- Carl
Carl Baze is offline   Reply With Quote
Old 06-18-2011, 08:47 PM   #2
You'll need to replace the tank. There should be no water in the top portion of the tank. The presence of water indicates that the bladder that separates the pressurized air from the water has ruptured.
Ishmael is offline   Reply With Quote
Old 06-19-2011, 12:03 PM   #3
Thanks, Ishmael. That's what I was afraid of.
Old 06-19-2011, 01:02 PM   #4
Water Treatment
Rewards Points: 902
I would take a look at the fittings in that area, might be that the seal on the inside of the tank needs to be replaced and not the whole tank.
That type of tank has different fittings that can be replaced with out having to replace the whole set up.
Is there a book on that tank? it might have the parts list for finding the part at fault.
Akpsdvan is offline   Reply With Quote
H2OwTo Pressurized Water Tank problems Gary5579 Plumbing 4 12-11-2011 06:25 AM
Can I use existing hot water tank for radiant floor? Red Squirrel HVAC 4 12-14-2010 06:31 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Tank less water heater bidet vs tank type water heater bidet husband&me Plumbing 4 04-05-2010 10:59 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
