Fiberglass Tub Cracking Noise - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-01-2011, 09:31 AM   #1
fiberglass tub cracking noise
My daughter just bought a home it was built in 1980 when taking her first shower the tub nade a cracking noise and moves is this a problem
bskaggs is offline   Reply With Quote
Old 05-01-2011, 11:00 AM   #2
Buying the first round
LIHR's Avatar
Fiberglass is not the ideal material for shower receptors and tubs. Today high quality acrylic units are the preferred material if cast iron is out of the equation. But to answer your question, the tub was probably never installed properly and the cracking noise is the bottom of the tub flexing. There's probably small voids beneath the tub bottom allowing for the movement.
Live with it.
Thirty years old, time for a new bathroom.
http://www.ranteso.com/
LIHR is offline   Reply With Quote
Old 05-01-2011, 11:16 AM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
was that bathroom ever remodeled? If this was a recent install, I would suggest more investigation as it does sound like there is an installation problem that should be remedied. If it is original, I would go along with the other poster.
Old 05-02-2011, 06:33 AM   #4
Household Handyman
Rewards Points: 1,408
I have mentioned previously on this forum that this is a common problem I find in my "HandyMan" business, and there is a solution rather than pulling the tub/shower unit. This involves shooting something like "Great Foam" between the tub/shower unit's bottom and the flooring IF you can gain access to this area. This is not always easy, but a do-able project. Your daughter has now invested monies into this home and has to decide what to do before a crack develops that will leak water.
Rattling Noise from Roof when windy drgillian Roofing/Siding 3 02-18-2011 10:05 AM
can you help me with this really odd noise? tuffluck Electrical 15 01-10-2011 06:35 PM
cellulose over blown in fiberglass? deerhunter Building & Construction 1 10-29-2010 11:16 PM
Noisy furnace (with recording of noise) Jeffrey HVAC 3 01-23-2010 02:17 PM
Fiberglass tub cracking sound, fixing with Mortar? markmisky Plumbing 15 01-25-2009 05:36 PM
