Fiberglass Shower Repair - Plumbing - DIY Home Improvement | DIYChatroom
Poll: What would be best?
Poll Options
What would be best?
Old 01-05-2013, 01:07 PM   #16
Wow! Was there any access from below? Either in a basement/crawlspace or through the 1st floor ceiling? I had a similar leak to repair once, but I was able to do all the work through the shower valve hole and from below. I cut the copper pipe out, and snaked some PEX up to the valve.
Ishmael is offline   Reply With Quote
Old 01-05-2013, 01:23 PM   #17
Roofmaster
Rewards Points: 2,210
You know, you could probably temp this by cutting out the FG right up to the fake tile lines, back boarding the missing drywall and replacing it, and installing ceramic tile bedded in urethane or silicone sealant till it squeezes out the seams then cleaning up with alcohol. It would probably work for a while, at least you could take a shower again. I think I would rip out this POS. Put in a shower pan and screw up durock or wonderboard, and install ceramic tile were it mine. Tiling is really not all that hard and it looks a lot richer than a cheap ass FG insert.
The Following User Says Thank You to jagans For This Useful Post:
Perotoss (01-05-2013)
Tags
fiberglass , shower
Fiberglass shower stall scarrylarry Painting 2 02-24-2011 06:27 PM
Fiberglass shower removal Stephen S. Plumbing 4 01-16-2010 11:45 PM
Fiberglass shower repair ponch37300 Kitchen & Bath Remodeling 5 03-10-2009 03:43 PM
Shower door install in unplumb fiberglass surround screenporch21 Building & Construction 1 11-24-2008 02:36 PM
Fiberglass surround or tile shower 220-221 Remodeling 2 07-27-2008 08:42 AM
