Old 01-15-2010, 07:23 PM   #1
Fiberglass shower removal
I am in the process of gutting out the master shower and there's a standing fiberglass shower. How should I remove it ?
Do people just destroy it with power tools ? If so, how? Thank you.
Stephen S. is offline   Reply With Quote
Old 01-15-2010, 08:00 PM   #2
carefuly with a sawzal, stuff rag in drain, make sure water is off
Old 01-15-2010, 11:27 PM   #3
as tpolk suggested, shut off water, remove trim pieces including drain piece (threaded to drain line), remove drywall around tub. Tub will have flange (lip) nailed to studs. Pull loose from studs. Check behind tub walls if possible at that point for electrical lines, etc. Then cut up with sawzal.
cm3putter is offline   Reply With Quote
Old 01-16-2010, 11:50 PM   #4
Thanks for the advice. I cut the shower half way and get stucked ... how do I remove the water on/ off knob and detach the drain (threaded?).
Guess what I found behind the bathtub !!! Wasp nest !!! I wonder how they got there ...
Old 01-17-2010, 12:45 AM   #5
jlhaslip's Avatar
the water valve should have a 'pop off' cover in the middle of it. then unscrew the knob.
the drain is either held there with a screw, or it screws off as well. use a pair of needle nose pliers and put the tips in the grate then twist the handle.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Help with shower pan removal - 1960s bath jm71 Kitchen & Bath Remodeling 6 11-23-2009 08:54 PM
Backerboard under Fiberglass Shower Pan? BillyDIY Plumbing 2 12-17-2008 02:47 PM
Shower door install in unplumb fiberglass surround screenporch21 Building & Construction 1 11-24-2008 03:36 PM
