I just installed a Sterling fiberglass 3 piece tub/ tub walls….as I was doing the finishing I noticed a cracking sound as I stood in the tub…is this normal settling of the new fiberglass tub? My worst fear is a cracked tub!!!
The floor that the tub is on wasn’t quite level so I had to shim it a little with some ½ plywood strips that I wedged under the tub before I closed the wall. I did this just so it had some extra support…then again this tub had little plastic feet on the bottom with space in between ..
Any comments would be helpful
Thank you
Thank you
