Fiber Floor Under Shower Stall Base? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-01-2012, 08:27 PM   #1
Fiber floor under shower stall base?
I'm replacing a shower stall and will be putting down Tarkett fiber floor in the area. (it is a kind of linoleum that you don't glue down.
My question is should I put the flooring under the full shower base right up to the corners of the walls or just cut it up to the edge of the base?
Any thought on what is best or normal would be appreciated! Thanks!
Waterfroggy is offline   Reply With Quote
Old 05-01-2012, 08:36 PM   #2
Rewards Points: 616
that is a floating floor so i would cut it along shower curb
right out off installation instructions
"> Do not install cabinets on top of FiberFloorŽ when using the Glueless Installation "
i would consider shower pan the same as cabinet
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 05-02-2012, 12:01 PM   #3
Ah, thanks!
Old 05-02-2012, 10:01 PM   #4
Rewards Points: 582
not sure i understand... if your replacing shower stall....why put linoeum under unit....we use portland cement to sure up bottom of unit???? did i miss something..
Old 05-03-2012, 09:37 AM   #5
Rewards Points: 99
I used the same stuff in the bathroom I am building. I have installed the base on top of the floor. I will see what happens and if need be I will cut the outline of the base and vanity. I can't understand why it really matters. it can't contract expand that much in a controlled temperature environment.
dwcopple is offline   Reply With Quote
Old 05-03-2012, 07:22 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
I think he was wanting to use the pan to hold the edges down and help keep water out of there.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 05-03-2012, 07:25 PM   #7
plummen's Avatar
Personally Ive always prefered to install the vinyl under base of toilet or anything else possible to help hold the edges down,then just caulked around it.
Im no master vinyl guy though!
The Following User Says Thank You to plummen For This Useful Post:
ben's plumbing (05-03-2012)
Possibility of enclosing a glass shower stall with shower curtains. cathyon1 Kitchen & Bath Remodeling 1 01-15-2012 05:25 PM
Glass block window in tiled shower stall ddmcc Windows and Doors 16 01-04-2012 11:48 PM
replacing wet wood under linoleum in front of shower stall Pawl Building & Construction 7 01-01-2012 04:11 AM
Finding 32 inch shower stall KaiGywer Kitchen & Bath Remodeling 2 05-17-2011 07:54 PM
Fiberglass Shower Base Install Q's yohan Plumbing 8 01-07-2011 04:46 PM
