Few Questions - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-09-2010, 12:36 PM   #1
Few Questions
I have a couple questions
i plan on moving washer and dryer to new location when i reno the basement it will be close to the main stack witch i plan on plumbing into the main stack.(should be doable as long as i put in a trap) right?
i would run a 1 1/2 off the main 3 inch vertical stack
The old washer drain is cemented into the floor i would like to cap this drain
1) can i cap it? i was thinking bust cement back till i could plumb a cap on it then replace the cement with new
i would also like to cap another hole that comes to the surface that i think was ment to be a snake hole but it has a t on the main sewer line so a snake would never go down it. was going to do the same thing for this hole. i would then plumb in a snake access further up the main stack in the furnace room.
just got this House a while ago the toilet doesn't want to flush and drian properly the toilet is new and everything inside the toilet is working properly... im thinking its the drain it runs about 2 feet straight down then 90 to straight to the main stack and connects at a T. I was thinking of replacing the drain with a 45 higher up to a 45 in the main stack would that do the trick?
I also plan on fixing an existing problem while doing the basement which is water supply. Our well is about 500m away from the house. tin the pump house there is a 3/4hp jet pump and pressure system on a 20/40 switch. If we run the water for a long time the pump over heats and auto shuts off.
I was told i should put in a valve.... my neighbor who has a similar set up uses a deep well pump that is 220v they have no problems i was thinking about going that route. Money is no issue what is my best option?
blunt22man is offline   Reply With Quote
Old 09-09-2010, 01:15 PM   #2
Owner
LateralConcepts's Avatar
Maybe take some pictures
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 09-09-2010, 06:27 PM   #3
every pic i take is to big how to get it to post?
Old 09-09-2010, 07:51 PM   #4
Rewards Points: 266
How to post pictures How to attach a photo to a post
Jim F is offline   Reply With Quote
Old 09-09-2010, 10:22 PM   #5
eah i got that far the pictures are too big
Old 09-09-2010, 10:41 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 442
I'll take a stab--
*You can tie your washer to your stack but it needs to be 2" pipe, trapped and vented with min. 1 1/2" vent
*Cap your old line at either location
*Don't understand your cleanout arrangement
*Pull the toilet and check the stub for blockage. I don't think you need to reconfigure the drain. How you propose to do it isn't code (if I understood your post)
I won't comment on your well, don't know much about them
Old 09-10-2010, 03:02 PM   #7
Rewards Points: 352
Originally Posted by TheEplumber View Post
I'll take a stab--
what he said
plumberinlaw is offline   Reply With Quote
Old 09-10-2010, 08:38 PM   #8
Sorry about the crap paint pic
on the right is how it is and the left is what i was talking
the one on left goes straight down to a 90 then connects to the main stack at a T
the one on the right would use 2 45's
What would be code?
this house is in a RM where code doesn't matter but i would like to make it functional. The toilet has been apart and there is no blockage
thanks for the info
Old 09-10-2010, 09:30 PM   #9
Plumber
Rewards Points: 442
You can't convince me that your current toilet pipe layout is causing your problem. That is the common and correct pipe arrangement. Camera and/or cable from your flange to the base of the stack. I still suspect a blockage.
Better still, pull the toilet and pour a few large buckets of water down the drain. If it takes it then suspect your toilet.
Old 09-10-2010, 10:06 PM   #10
OK I'll rip it out again and have a look
Old 09-10-2010, 10:31 PM   #11
also
http://www.homedepot.ca/webapp/wcs/s...k=P_PartNumber
Anyone use these?
i have a couple dehumidifier units that were that much and only do 20 pints day
Old 09-14-2010, 08:30 AM   #12
Originally Posted by blunt22man View Post
no one?
Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions Tryvidy Electrical 9 06-18-2012 03:37 PM
How thick should my thinset be? yummy mummy Tiling, ceramics, marble 20 09-28-2009 01:36 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 11:56 PM
Hey gang, another Neewb here! 261,483 questions to follow! Portlandkids Flooring 6 08-30-2008 09:34 PM
tiling questions - in middle of install mwill Flooring 8 12-11-2007 06:06 PM
