Ferrule Fitting Wont Come Off - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-25-2009, 06:29 PM   #1
Ferrule fitting wont come off
I got a hot water supply under the Kitchen sink. The Ferrule fitting on a 1/2 copper line, will not come off, I used WD-40 and no luck. It slides around about an 1 in. thats it.
Any ideas?
Please help.
evol200 is offline   Reply With Quote
Old 04-25-2009, 06:53 PM   #2
HVAC / Plumbing
is it where you can apply a little heat & work it back & forth ?
kenmac is offline   Reply With Quote
Old 04-25-2009, 06:55 PM   #3
I could, but water keeps dripping out even though I shut off the main valve.
Old 04-25-2009, 07:12 PM   #4
HVAC / Plumbing
Your main valve mabe bypassing a little . Or, it could be just what's left in the lines.. They can be difficult to get off . But they will come off. I've had to file some off
Old 04-25-2009, 07:16 PM   #5
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
If you're talking about a brass ferrule for a compression fitting, I'm surprised it moves even an inch. Once the compression nut is tightened the ferrule bites into the pipe forming a watertight seal. Though I've heard they make ferrule pullers, I've never seen one for sale or it would be on my truck right now. What I usually do is use a hacksaw blade and cut through the ferrule being careful not to cut the copper tubing. After I have the cut, I use a screwdriver to pry the ferrule apart.
JDC is offline   Reply With Quote
Old 04-25-2009, 07:32 PM   #6
Yeah its a compression fitting.
ok, i'll try cutting it then.
Old 04-25-2009, 07:49 PM   #7
HVAC / Plumbing
Do you have a dremel tool ?? I,ve also used 1 to cut them off .When, I didn't have room to just cut behind it
Old 04-25-2009, 09:01 PM   #8
I ended up just re-using the ferrule fitting again since I couldnt get it off. Since water was coming through the threaded fitting, I just applied plumbers tape (5 revolations) and plenty of muscle to make sure the fitting was secure. No leaks. Jeez what a chore this was for a simple Kitchen Faucet switchout.
My only other option would of been, was too cut off some pipe, remove the fitting and re-solder an extension to it, because there's really no room if I just cut it off. Whatever saves me a trip to the store, I just re-used it.
Thanks for the help.
Newbie Solder Question SteveSmith98 Plumbing 9 01-15-2009 09:50 PM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 05:30 PM
Cracked PVC fitting in concrete DJupin Plumbing 6 07-29-2008 03:12 PM
Reseal ABS fitting n0c7 Plumbing 4 05-28-2008 04:00 PM
Replace PEX fitting with Shark Bite Push Connector? larrybr45 Plumbing 3 01-27-2008 02:01 PM
