Old 12-04-2010, 03:57 PM   #1
ferncos !
Is there any reason I shouldn't use ferncos to connect ABS to ABS? I found a bunch of them left over from some other thing and I'm running out of my glue'm together couplers.
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 12-04-2010, 04:12 PM   #2
ferncos !
i was taught not to use fernco's above ground b/c they don't properly support the pipe
the_man is offline   Reply With Quote
Old 12-04-2010, 04:35 PM   #3
ferncos !
I do not think there is anything wrong with using ferncos, but you will need to put a few extra hangers to make sure the pipe stays square. It is true glue joints are more rigid, but I believe it will be fine.
broox is offline   Reply With Quote
