Old 03-09-2007, 08:52 AM   #1
fernco coupling
I'm weighing my options for repairing a leaking horizontal pvc drain pipe in my downstairs bath. It was caused by a long drywall screw that nicked it years ago and held up until now. I think I will replace the section of pipe and use fernco couplings since I can't push back either side far enough to use a pvc couplings. I've heard good things about the fernco couplings. Do you just clean the pvc, slide the coupling on and tighten the clamps or is there a sealer you have to put on the pipe first? thanks
farrington135 is offline   Reply With Quote
Old 03-09-2007, 09:08 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
fernco coupling
No sealer needed, slide it on, tighten up the clamps, walk away.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 03-09-2007, 10:12 AM   #3
fernco coupling
Thanks.
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
cast-iron to PVC banded coupling amakarevic Plumbing 1 07-14-2007 03:02 AM
Use of coupling fitting on gas pipe Fred Plumbing 3 01-28-2007 07:13 AM
Bathtub drain and w&O overflow connection Manuel6 Plumbing 5 11-03-2006 12:23 PM
Is coupling top plate necessary? Rufer Building & Construction 13 11-22-2005 10:39 AM
