Feed Experimental Chambers Cold Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-20-2013, 06:06 PM   #1
Feed Experimental chambers cold water
A lab is looking to remove the current two large chillers they are using to feed cold to there experimental chambers. These machines only recirculate the water as a cooling mechanism. The have installed air cooled room on the back side of the lab constant temp of 4c. They have tried placing a 300L tank in the room to keep the water cold and have a continuous 1/2" pex loop feeding the machines. The machines require a constant water temp between 5-12c. When all four chambers are runing the water temp in the tank reaches 21c. Is there a way to reduce the water temp with out useing lage chillers ? Attached is a sketch.
HVAC Designs is offline   Reply With Quote
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 07:03 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Leaking Water Heater (from Cold Inlet?) doesntmatter Plumbing 7 07-12-2010 10:30 PM
No cold water!! Hot coming out in the cold faucet! HELP Marilynjp Plumbing 6 01-04-2010 07:40 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
