Feed Boiler Off Pex Manifold Or Main Supply ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-08-2012, 07:01 PM   #1
Rewards Points: 150
Feed boiler off pex manifold or main supply ?
Going to start redoing my house with a pex manifold.
Would it be better to have a cold water feed off my pex manifold that goes to my boiler or have it "T" off my main 3/4 supply line before it goes into the manifold?
I realize both will work, but what is typically done in this case?
thanks
alecmcmahon is offline   Reply With Quote
Old 02-08-2012, 07:13 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Is the manifold going to have shout off valves to each of the pex runs?
Are you using a mana block system?
I would run off the manifold.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 02-08-2012, 07:15 PM   #3
Rewards Points: 150
yea, everything gets its own homerun, and has its own shut off, looks like this:
Old 02-08-2012, 07:17 PM   #4
Rewards Points: 560
Run an individual run if it were me.
replumb: approved way to bring main water supply up to attic and into house? hal74 Plumbing 0 11-07-2011 08:36 AM
Boiler oil supply line- Hard copper? alecmcmahon Plumbing 0 03-23-2011 09:35 PM
Darn. A leak in my main supply from street, Galvanized. In foundation under slab? twilightcall Plumbing 2 07-31-2008 12:22 AM
Ground Main Water Supply? blueboy27 Electrical 17 11-04-2007 12:38 AM
Turning main power supply off from the meter amakarevic Electrical 2 05-22-2007 10:33 PM
