Faulty Faucet? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-11-2012, 08:40 AM   #1
Faulty Faucet?
Good morning,
I changed out a faucet several days ago. The hot water side of the new faucet runs very slowly, as compared to the old faucet. The cold water side is fine. The new faucet is a Glacier Bay which uses cartridges to regulate water output. Suspecting the cartridge to be defective, Glacier Bay sent me a new cartridge. After installing the new cartridge, the water output is exactly the same. I've checked the hot water service to the faucet and everything seems to be fine.
Before I remove the faucet to check for an obstruction between the cartridge and the spout (unlikely?), I thought that I'd post this to see whether anyone has had experience with this type of problem.
Any ideas?
Thank you,
DJ
dwlodyka is offline   Reply With Quote
Old 04-11-2012, 08:53 AM   #2
Rewards Points: 12,812
Shut the water off to the hot side, disconnect it from under the faucet. Set a bucket under the sink and turn the water back on to check water flow.
The faucet you bought is the lowest of the lower priced faucets. I've seen lots of people on other DIY sites have the same problum with that brand.
I tryed using them in a rental and had to replace all of them because of leaks and the finish failing within a few years.
Pressure Change on Outdoor Faucet mrhudock Plumbing 0 04-11-2011 10:34 PM
unable to stop leaky kitchen faucet w/ new valve diy888 Plumbing 0 02-27-2011 09:45 AM
Selecting a New Kitchen Faucet klumbsy Kitchen & Bath Remodeling 4 02-25-2011 09:29 AM
Ice in Cover over Exterior Faucet SPetty General DIY Discussions 13 01-11-2010 04:32 PM
Washing Machine Faucet handy man88 Plumbing 5 03-23-2009 02:25 PM
