Faucets At Home Depot And Lowes - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-19-2009, 09:12 AM   #1
Faucets at Home Depot and Lowes
Are brand name faucets sold at Home Depot and Lowes equal in quality to the same brand sold at plumbing supply stores?
lebosh is offline   Reply With Quote
Old 06-19-2009, 12:00 PM   #2
DIY'r
ScottR's Avatar
If a fixture is the same brand/model, then it's exactly the same at any vendor. <-- EDIT: with exceptions, per faucetman below..
HD and Lowes do sell some quality stuff, but also a good amount of crap -- in the end you get what you pay for. A $50 Kholer faucet is not going to be as good as a $200 Kholer faucet. Within the brands there is a range of quality.
Plumbing supply houses might have a better selection of higher-end fixtures than the big boxes, though.
ScottR is offline   Reply With Quote
Old 06-19-2009, 02:28 PM   #3
They do make slightly different versions for the big box stores
I'm not sure of the exact differences, but either on this site or another they did point out significant differences
Old 06-19-2009, 02:34 PM   #4
In general I agree with Scott but there are some exceptions to the rule and you really have to watch item numbers and descriptions to make sure you are getting the exact same item. I was recently cited Price Pfister item #T43-YP0Y (Ashfield Bathroom sink faucet) as a prime example. Same faucet same part number but in the description one says 100% metal the other 50/50 plastic metal. The manufacturers are making less expensive versions of some of their lines by making some of the fixtures and ancillary parts of plastic instead of all metal and sometimes you may also find that fixures in one store will contain all the parts you need as in a pop up drain, gaskets etc and another of the same part number will only contain the fixture and no other parts. Just be aware of what you are buying and compare items carefully from store to store.
faucetman886 is offline   Reply With Quote
Old 06-19-2009, 03:03 PM   #5
DIY'r
ScottR's Avatar
Oh man, I knew they sometimes sell dumbed-down versions of fixtures for the big boxes, but I didn't know they'd use the same part #?!
Thanks for the heads-up though, now I'll be on the lookout for that sort of thing..
Thoughts and opinions on "Trafficmaster Allure" flooring from Home Depot? zel Flooring 849 07-28-2015 01:31 AM
Is there a "high class" home depot? njhomer General DIY Discussions 28 12-06-2011 12:08 PM
A word of caution regarding WATTS waste overflow kit from Home Depot and Lowes... J187 Plumbing 7 04-03-2009 05:08 PM
big bug zapper from lowes? musiclady Pest Control 2 08-09-2008 02:28 PM
