Faucets With Grooves - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-13-2010, 08:55 AM   #1
Faucets with grooves
Hi, we have some faucets that have ‘covers’ on the tip of them (you can see it in the pic with grooves). I want to adjust the water flow or perhaps even remove these (currently the water is all over the plce as these are clogged/dirty I assume). I’ve heard that there is a tool to fit into these groves to adjust/removed these tips.
Do you folks know where can I find this tool? Or what is it called? HD or Lowes were no help. Thanks
dwheelie is offline   Reply With Quote
Old 07-13-2010, 11:36 AM   #2
Rewards Points: 1,542
Do you have a stiff non-valuable strip of metal such as a hacksaw blade that will fit in both grooves and then you use a monkey wrench spanning the same strip to use the strip as if it were a very wide screwdriver blade to unscrew the faucet tip?
Do not use a good tool such as scissors to go in the grooves as whatever you use will be somewhat deformed when you are done.
Old 07-13-2010, 01:44 PM   #3
I tried with a thick blade, that broke. These must be stuck on there tight.
Old 07-13-2010, 04:14 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
take a plastic bag and put white vinegar in it. The tie it over the spout so the end is well submerged and let it set at least overnight but 24 hours would be better.
That will dissolve any lime buildup which typically acts like glue to make removing the parts difficult. You might find that after doing that, you don't even have to remove the nozzle.
Old 07-13-2010, 05:15 PM   #5
I use needle nose pliers and a vise grip and you have to push very hard because the pliers want to come out of the slots.
Use joint compound over grooves in paneling that have already been painted ? lilsis Painting 2 04-01-2010 12:57 PM
Door jamb grooves necessary? Cossack Carpentry 8 03-04-2010 09:56 AM
Crane two handle kitchen deck faucets Nestor_Kelebay Plumbing 1 06-23-2009 08:28 AM
Repair/Rebuild antique faucets bofusmosby Plumbing 8 11-25-2008 05:59 PM
Faucets - Reduced Water Flow wallydj Plumbing 5 02-18-2008 04:35 PM
