Faucet Water Won't Turn Off. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-05-2008, 02:08 PM   #1
Gunraidan's Avatar
The Kitchen Faucet just won't turn off. Even when I twist it to off some (or even a lot) of water still runs. It isn't both of the twisty things though (I don't know what it's called) just the one for the hot water (the one to the left).
If I push it down to give it pressure the water shuts off, but as soon as I start to take my hand off of it the water still runs.
Do you people know how to fix it? Please.
EDIT - It's called a handle! The Twisty Thing is called a handle!
Last edited by Gunraidan; 01-05-2008 at 02:11 PM. Reason: Just Remembered what it's called
Gunraidan is offline   Reply With Quote
Old 01-05-2008, 02:22 PM   #2
Oldguy
Rehabber's Avatar
You are TOO funny Below the faucet (inside the cabinet ) there should be two valves mounted on the wall. (they are called anglestops) turn off the left one and the water should stop running. Then you can remove the handle and then the valve. Take it with you to your local hardware store and purchase replacements and then reinstall.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 01-06-2008, 12:30 AM   #3
Gunraidan's Avatar
Originally Posted by Rehabber View Post
You are TOO funny
I'm sorry it's not my fault I'm stupid.
Not to sound even more clueless then I already am but how exactly do I take the valves off?
Old 01-06-2008, 12:45 AM   #4
Oldguy
Rehabber's Avatar
With most faucets, there will be a small cover (that usually says H or C) on the handle. Pry this off, and there will be a screw underneath. remove the screw and pull the handle up and off. You should then see a hex shape and you use a wrench to turn it counterclockwise to remove it. Make sure that the anglestop has stopped all the water flow before starting this procedure. If this doesn't make any sense to you, it may be time to call a plumber.
Old 01-06-2008, 12:48 AM   #5
Master Plumber
Rewards Points: 150
Turn the valve (angle stop) off under the sink, turn the handle on the faucet above to make sure the water is off. Use a screwdriver to remove the faucet knob then use a pair of channel locks to remove the faucet stem....I could go on but I have a feeling you may be in over your head...if you really want to try this there a ppl on here that will walk you through it further (maybe even me) another option is to go buy a nice new faucet and supply lines and try to put that in... or...ehem, have someone do it for you. I will check back in a few.
jpplumber is offline   Reply With Quote
Old 01-06-2008, 12:55 AM   #6
Gunraidan's Avatar
Would should I pry it off with?
Channel Locks? Sorry but I don't know what that is.
Old 01-06-2008, 01:05 AM   #7
Master Plumber
Rewards Points: 150
I rest my case. Call a plumber
Old 01-09-2008, 08:48 PM   #8
Gunraidan's Avatar
Okay.
Just a question though where can I learn this stuff? I mean pluming and what not?
Old 01-09-2008, 08:58 PM   #9
Oldguy
Rehabber's Avatar
Call a plumber or handyman, ask if they will be willing to teach you while they are fixing the problem. If they are not willing, call another till you find one.
Old 01-09-2008, 10:28 PM   #10
Res Ipsa Loquitur
Originally Posted by Gunraidan View Post
Okay.
There are many general allaround repair books in most homecenters or book stores. Better yet there are specific books such as basic plumbing, basic electrical etc that go more in depth than the general books. Getting one with color pictures can be helpful too.
handyman78 is offline   Reply With Quote
Old 01-09-2008, 11:52 PM   #11
Gunraidan's Avatar
Okay, thanks for the help everyone.
Help! hot water won't stop running despite faucet changes. nodak_luke Plumbing 4 12-14-2007 06:38 PM
No hot water @ faucet Piney Plumbing 8 10-29-2007 07:31 AM
Faucet options for undercounter water filter mdr25 Plumbing 4 03-02-2007 05:56 PM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 03:17 AM
Faucet won't turn off etiger Plumbing 1 08-31-2005 03:46 AM
