Faucet Turns Itself On - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-23-2008, 10:50 AM   #1
faucet turns itself on
the cold water faucets in both my bathroom sink and tub turn themselves back on. fixtures are probably 40 yrs old. need to replace them or might new washers fix the problem?
palawler is offline   Reply With Quote
Old 06-23-2008, 12:22 PM   #2
Two things I can think of. Since the fixtures are old, you probably have two handles (hot and cold). The packing nuts that hold the stems in could be loose and allowing the water pressure to turn them to the open position. There is also a rubber washer on the end of the stems that seal when the faucets are turned off. These could be worn also. Both are easy fixes.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 06-23-2008, 06:25 PM   #3
thanks, majakdragon, for your help. in the meantime, the hotwater heater has died, leaking water all over ..........the faucets don't look so bad now.
Old 06-23-2008, 07:40 PM   #4
When it rains, it pours.....literally.
Tags
bathroom faucet , fixture , washer
Faucet Drain Lever Installation DK75 Plumbing 3 05-21-2008 11:08 AM
Help! hot water won't stop running despite faucet changes. nodak_luke Plumbing 4 12-14-2007 06:38 PM
Does faucet attach to grante or...? sil Plumbing 2 11-22-2007 03:22 PM
Question about a kitchen faucet skwpt Plumbing 10 10-11-2007 07:54 PM
Repair outdoor faucet? mx13 Plumbing 3 04-09-2007 07:08 PM
