Faucet Too Far From Wall - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-20-2013, 12:31 PM   #1
Faucet too far from Wall
How difficult would it be to repair this? I am afraid of water getting into the wall from this spot, it was like this when I bought the house. My kids have been using this tub to take baths but my daughter is old enough now to take a shower. I'm guessing this space is too huge to caulk up. I want to fix this before it becomes a real problem. I tried twisting the faucet but it doesn't move any closer to the wall. The facuet also drips indefinitely when turning off the water sometimes (not all the time). Sometimes you have to fidget with it (turn it on a bit, turn it off) before it will stop leaking, though I realize this is a separate problem. Also, it should be noted that the pipe that the facuet is attached to does not seem to be secure inside the wall. I can easily move it around. Your suggestions and advice would be appreciated. I am hoping this can all be repaired without having to open the wall, because it's a plastic faux tile shindig that surrounds the entire tub. Pics attached.
Faucet too far from Wall-wp_20130120_001.jpg   Faucet too far from Wall-wp_20130120_004.jpg
lungcorn is offline   Reply With Quote
Old 01-20-2013, 12:49 PM   #2
DIY staff
Rewards Points: 7,174
There is a set screw under that that holds the spout to the pipe--if that is a push on style---
An Allen wrench is needed to turn the screw----see if you have one---of so---loosen the screw and push the spout back on place----
If not--come tell us---
lungcorn (01-20-2013)
Old 01-20-2013, 01:18 PM   #3
Doh! It was that easy, but there is still a small gap -- However, it's now small enough that I feel comfortable caulking it. Thanks Mike!
Old 01-20-2013, 01:30 PM   #4
funfool's Avatar
Rewards Points: 534
In that case, all you need to do is loosen it and slide it off, cut the pipe shorter or replace with a shorter pipe, then slide it back on.
Or leave it as is and caulk.
funfool is offline   Reply With Quote
Old 01-20-2013, 01:38 PM   #5
Unfortunately the bottom of the faucet is up against the wall but the top has a bit of a gap; like the pipe isn't perfectly level. Not surprising with all the shortcuts builders take these days. But the gap was small enough that I was able to caulk it nicely. Thanks guys.
The Following User Says Thank You to lungcorn For This Useful Post:
oh'mike (01-20-2013)
Old 01-20-2013, 02:48 PM   #6
Rewards Points: 14,306
To find out why you would have to open up the back side of the wall.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Creating doorways/supporting wall issues NWVintage Remodeling 2 12-19-2012 03:19 PM
Can this be done without going behind the wall: overflow cover and faucet seals/seats abefroman Plumbing 1 01-13-2012 03:02 PM
How to calculate total glazing allowed in a wall? dalepres Building & Construction 3 04-22-2011 12:28 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
