Faucet Supply Line Types. - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-17-2010, 12:32 PM   #1
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Faucet supply line types.
Plumbing isn't my forte but I'm about to put a new bathroom sink faucet in for my grandmother this afternoon. My father has bought new PEX supply lines for it. These type of lines have always been problematic for me in the past. They tend to develop leaks near the shut offs on my own faucets. I'm wondering if there is a better option to use. I see tons of different types. I'm leaning toward a braided PVC but can't find much info on it. I've heard the braided steel may look good but tend to have cheap tubing inside that doesn't stand the test of time. Any input is appreciated.
Thanks.
poppameth is offline   Reply With Quote
Old 05-17-2010, 12:58 PM   #2
Rewards Points: 876
Could your problems with PEX be that you are over-tightening the compression nuts on the shutoffs?
Also, make sure you're not putting too tight a bend in the PEX.
I replaced a kitchen faucet set a year ago that has PEX tubing running directly into the fixture, so I had no choice to use it or not. I have not had any trouble at all. Just pay close attention to install instructions.
FW
Ultrarunner2017 is online now   Reply With Quote
Old 05-17-2010, 01:45 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
At the compression end (valve) of the PEX, be sure to use a plastic ferrule and not a brass ferrule.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 05-17-2010, 03:31 PM   #4
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Yeah we've used a plastic ferrule and I made sure there was almost no bend in the line last time. Knowing my father though, over tightening could very well be an issue.
Old 05-17-2010, 08:33 PM   #5
Rewards Points: 876
I used metal ferrules on the PEX on my kitchen install a year ago, and no leaks yet.
I plan to replace them with plastic ones when I get around to replacing the shutoffs. I've had the new ball valves waiting for installation, but haven't got to it yet.
That said; I would not recommend using the metal ferrules with PEX. It can cut into the tube and cause a leak.
FW
Fixing Leak in Well Supply Line Weekend Warrior DIY Plumbing 4 06-25-2010 07:28 AM
Capacity loss with line size Einride HVAC 1 06-29-2009 03:10 PM
Underground Supply line, 3/4" poly or type K Mr Chips Plumbing 7 03-25-2009 10:59 PM
add an additional register to a supply line b2v HVAC 1 06-20-2006 06:55 PM
hot pilot light supply line dlkk HVAC 1 02-24-2006 05:45 PM
