-   -   Faucet Replacement - not sure what to do about the counter holes... (http://www.diychatroom.com/f7/faucet-replacement-not-sure-what-do-about-counter-holes-125219/)
kymira 12-01-2011 11:19 AM
Hi there this will be my first faucet replacement. After constantly replacing and checking both compression stems Ive finally decided just to replace the whole thing.
This is my current faucet :
http://img191.imageshack.us/img191/7981/img029dv.jpg
Underneath the counter :
http://img856.imageshack.us/img856/8572/img027lr.jpg
Id like to replace it with a faucet similar to this type:
http://www.faucetdepot.com/faucetdep...hen-faucet.jpg
Now my concern is the newer faucet's base is much narrower than my old one. I have no problem drilling new "center" hole on my counter, but how do I cover up the existing holes which the new faucet will mostly likely partially overlap.
Is there a type of plate I can use underneath the new faucet base? other options?
Any thoughts or suggestions will be greatly appreciated.
Bud Cline 12-01-2011 11:26 AM
Get your new faucet and see if that's the case first.
Lightfoot 12-01-2011 11:41 AM
I agree with Bud.
Most of the new kitchen faucets i've put in recently are just wide enough to cover the old holes (some barely, but they still covered).
kymira 12-01-2011 11:49 AM
I see your point. But Hypothetically when one runs into this problem.. what are their options?
Ironlight 12-01-2011 12:26 PM
In your situation most people buy a faucet that is the same configuration as they one they are replacing. For you that would be two-handle widespread 8" centers. There are three hole single lever faucets that use widespread holes so see if you can find one that you like and it will make your job easy. Your selection will go down when you add the pullout feature but you can probably find one.
If you want to go with a different config that is not three hole wide spread then you need to see if the width measurement of whatever flange it has is wide enough to cover your old holes. Probably isn't. Buy locally if you're not sure or you'll pay return shipping and probably at least 10% restocking if you have to return it.
If you are set on that specific faucet and want to plug the holes and not have it look like a$$, that is going to be tough. I would probably find a piece of laminate that matches as best as possible, cut it to cover, glue it down, and rebore for your new configuration.
Here is a three-hole widespread single lever faucet. This is the route I would go if I were in your shoes:
http://www.efaucets.com/detail.asp?Product_Id=7425
kymira 12-01-2011 12:42 PM
thanks Ironlight. I didnt realize how much work it would be just to change faucet styles. I'll weigh out my options and re-post with my final results :)
Ironlight 12-01-2011 01:34 PM
It's not a lot of work, you just need to choose wisely so it's NOT a lot of work, lol. And you're doing your homework now which means you'll save yourself a bunch of grief, or at least know what you're getting into, when it comes to installing the thing.
I should have been clearer about one thing...some single lever faucets, even if they only require a single hole for installation, come with "deck plates" for exactly your purpose of covering existing holes. Just make sure that the faucet comes with a deck plate wide enough to cover 8" on-center holes. Some may be wide enough to only cover 4" holes. The specifications of any given faucet should give you the width of any included deck plate.
kymira 12-01-2011 02:02 PM
Yes the faucet Im looking at does have an optional deck plate. I'll probably run to the store before hand and measure it first.
Bud Cline 12-01-2011 02:58 PM
Get your new faucet and see if you even have a problem before you take away years of your life worrying about nothing.:thumbsup:
kymira 12-01-2011 03:17 PM
I like to plan ahead before problems arise. Not to worry, Im still young and have plenty of years to kill, old man :thumbsup:
BTW if it does end up being too narrow, Im thinking something this would help with the cover up:
http://www.amazon.com/gp/product/B00...d_i=B001HBPHRW
