Faucet Replaced But Water Still Running - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-09-2010, 06:01 PM   #1
Faucet replaced but water still running
I successfully replaced the entire cold faucet (new washers of course) but the water still won't turn off. And it's not just dripping. I've got a steady stream of cold water.
Any thoughts? I hate having to go outside and turn off all the water .... especially in the rain.
-KR
catzpah is offline   Reply With Quote
Old 02-09-2010, 06:39 PM   #2
Household Handyman
Rewards Points: 1,408
Errr, Ahhh, you replaced the washer, right? What about the "seat" the washer seals against? One small chip=one large dribble. David
Old 02-09-2010, 07:13 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Journeyman Plumber
Old 02-09-2010, 08:43 PM   #4
Yup -- replaced the seat and the washer. So I dunno....it's frustrating. Can't see any chips anywhere. If the water pressure is too high, could that make it leak? -KR
Old 02-09-2010, 08:49 PM   #5
Doing it myself
Alan's Avatar
Yes it could. Check your pressure.
Also, when you replaced the washer, were there stamped numbers and letters on it? Sometimes we have to shave them off to get the washer to sit flat.
Journeyman Plumber
Old 02-10-2010, 02:12 PM   #6
I'll check for the numbers and the water pressure.
Also fixed part of the problem by replacing the other faucet which did have a big chip.
Thanks for the advice! -- KR
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
Installing Faucet with cold water only - How to cap off hot water inlet? jrterry1976 Plumbing 3 02-27-2009 07:27 AM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
constant running water sound gmk2008 Plumbing 9 11-11-2008 08:22 PM
