Faucet Opens In Both Directions - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-06-2011, 03:12 PM   #1
P Marage's Avatar
Rewards Points: 87
Faucet opens in both directions
What would cause the faucet in my bathtub to run in both directions?
There is a point where the water stops(not completely) but lately when I turn the tap all the way shut the water flow increases. Would it be the internal mechanism or would replacing the seal fix this problem? Any advice I thank you for in advance.
P Marage is offline   Reply With Quote
Old 03-06-2011, 05:06 PM   #2
normally there is a stop built into the handle that stops it from spinning all the way around. i'd bet that yours is broken. what kind of valve is it?
the_man is offline   Reply With Quote
Old 03-06-2011, 05:08 PM   #3
P Marage's Avatar
Rewards Points: 87
Waltec
Old 03-06-2011, 05:49 PM   #4
Rewards Points: 1,512
One of the gaskets or seals or one of the moving parts inside is excessively worn.
A faucet of this kind typically has a rotating disk with a hole off center. The handle goes about half a turn maximum. When the handle is turned the disk also turns and the hole is either lined up with or not lined up with a hole in a stationary disk. should either disk itself or the gasket between the disks be worn, you can get the problem you describe.
Or the stop mentioned above, if broken, will result in this problem. In an extreme case the handle will rotate 360 degrees with the water turning off and back on full again.
Old 03-08-2011, 09:27 AM   #5
P Marage's Avatar
Rewards Points: 87
Thanx for all your help guys turns out it was just a seal that seats way in the back of the piping was crushed. Replaced it and all is well again back at camp Marage
unable to stop leaky kitchen faucet w/ new valve diy888 Plumbing 0 02-27-2011 08:45 AM
Selecting a New Kitchen Faucet klumbsy Kitchen & Bath Remodeling 4 02-25-2011 08:29 AM
Ice in Cover over Exterior Faucet SPetty General DIY Discussions 13 01-11-2010 03:32 PM
Washing Machine Faucet handy man88 Plumbing 5 03-23-2009 01:25 PM
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 05:10 AM
