Faucet Nut Behind Deep Kitchen Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-11-2012, 08:21 PM   #1
Faucet nut behind deep kitchen sink
So as long as I've had my deep basin kitchen sink, I have been unable to securely tighten the nut that fastens the faucet to it. Are there tips or tricks to this?
The space is too small to get an adjustable wrench in there, and I'm not sure a crescent wrench would even work (I don't have one big enough anyway). I have strong fingers and am able to tighten it enough to make it usable. But a key feature of the faucet is that it swivels, which eventually loosens the nut (and the handle then becomes quite loose and wont stay in the on position; friends call it the auto-shutoff faucet).
-Don
radon is offline   Reply With Quote
Old 07-11-2012, 08:32 PM   #2
Rewards Points: 582
-Don
picture would help
Old 07-11-2012, 08:45 PM   #3
DIY staff
Rewards Points: 7,174
Have you tried a basin wrench?
PaliBob (07-11-2012)
Old 07-11-2012, 09:20 PM   #4
I had never heard of a basin wrench... that may work! Thanks! Since 'ben's plumbing' asked, here are pictures from below and above...
2012-07-11_21-42-27_522 by radon220, on Flickr
2012-07-11_21-44-51_208 by radon220, on Flickr
Old 07-11-2012, 09:23 PM   #5
Rewards Points: 6,652
Yep, basin wrench will work. Remember that the head flips, depending on which way you are planning on turning. They do make them with the shaft that extends, or with longer shafts. Usually kept in the plumbing aisle at big orange, Lowe's, Ace Hardware.
Old 07-11-2012, 09:26 PM   #6
Rewards Points: 582
yes a basin wrench will work...but i stand by my thinking if 30 yrs old replace it with your new basin wrench
Old 07-11-2012, 09:48 PM   #7
DIY staff
Wrong thread,Ben----that was the Allen set screw guy---
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
ben's plumbing (07-12-2012), VIPlumber (07-11-2012)
Delta kitchen faucet is leaking under the sink grave20 Plumbing 2 04-01-2012 01:00 PM
Resetting Undermount Kitchen Sink Voss Plumbing 0 02-24-2012 12:47 PM
Kitchen sink venting issue erm213 Plumbing 9 05-24-2011 02:01 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
Smell Under Kitchen Sink mamaerin General DIY Discussions 4 09-23-2009 11:01 AM
