Faucet Not Changing Temperature - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-07-2009, 09:05 PM   #1
Question
Faucet not changing temperature
I'm a real estate agent in CT. I have a client that had their building inspection yesterday on a 9 year old townhouse. All faucets in the unit do work, making the water both hot & cold. However, the faucet in the upstairs guest bath tub does not make the water any warmer or any cooler after the inspector turned the knobs. Does anyone know to the fix this problem or what caused this problem, and have an idea on what it is going to cost?
Thanks-Jon
ctrealestate is offline   Reply With Quote
Old 10-08-2009, 07:22 AM   #2
Pressure balanced faucets have limit stops that may need to be set. Most require removing the handle to get at the mechanism, and every manufacturer does theirs a bit different, so I can't explain them all here. It usually involves moving a gear to allow more travel in the hot direction.
Old 10-08-2009, 07:45 AM   #3
the Musigician
DangerMouse's Avatar
or it could be as simple as someone turned off the hot water valve inside the vanity.... or the cold, depending on what comes out.
DM
Old 10-08-2009, 04:22 PM   #4
Thanks for the help. I was out at the house again this afternoon with their building inspector. The average temperature going out for the bath tub fixture was around 117 degrees, but as the water passed through the showerhead and into the air where you would shower, the temperature was down til about 95 degrees . It could either be a blocked or turned off valve in the basement or in the faucet.
Old 10-08-2009, 04:39 PM   #5
the Musigician
hmm... tub, ok.... i need to learn to read better.
the likely culprit could be a temp/pressure valve under the tub knob. it would just need adjusting if so.
DM
Tags
faucet fixtures , faucet repair , water temperature
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 08:42 PM
Washing Machine Faucet handy man88 Plumbing 5 03-23-2009 02:25 PM
Opinion needed about changing kitchen faucet chris_p Plumbing 11 02-01-2009 11:39 PM
how to stop condensation on windows? cake General DIY Discussions 7 11-22-2008 01:12 AM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 03:41 PM
