Faucet Leak Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-15-2008, 04:31 PM   #1
Faucet leak problem
I've had this problem for a long time and I finally feel like fixing it. The faucet doesn't exactly leak. When I turn the handle off completely, faces straight left or right, the water runs. When I leave it at an angle the water stops. It's annoying cause I always have to leave the handle at the right angle.
The O-rings seem fine, but the cartridge does seem really old. I have no idea how to fix this.
Chaoz is offline   Reply With Quote
Old 08-15-2008, 04:51 PM   #2
Rewards Points: 2,906
Could you please tell us what kind of faucet this is?
Nestor_Kelebay is offline   Reply With Quote
Old 08-15-2008, 05:10 PM   #3
Journeyman Plumber
Ron The Plumber's Avatar
Can't you reposition the handle by removing it, so it's in the position you want it at?
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 08-15-2008, 05:20 PM   #4
I tried that. No matter what position I set it in, I always have to turn the handle slightly to make the water stop.
And it's a compression type faucet.
Old 08-15-2008, 05:20 PM   #5
Journeyman Plumber
What brand is this faucet?
Old 08-15-2008, 05:30 PM   #6
Price Pfister. Don't know the exact model though.
Old 08-15-2008, 05:31 PM   #7
Journeyman Plumber
Are the stems not of the spline type?
Old 08-15-2008, 05:44 PM   #8
I have no idea what that means.
Old 08-15-2008, 05:45 PM   #9
Journeyman Plumber
Take the handle off, where the handle connects to the stem, can you post a picture, that would be useful.
Old 08-15-2008, 05:48 PM   #10
Will do, but can't until tomorrow.
Old 08-15-2008, 09:41 PM   #11
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Waiting in the wings..........
Journeyman Plumber
Old 08-15-2008, 10:02 PM   #12
Journeyman Plumber
Good catch, I think it's a peerlees faucet, the cam can be tricky to line up, but yes is this a single lever faucet? Describe it if you can.
Old 08-16-2008, 02:10 PM   #13
Here are the pics
http://c.imagehost.org/0213/IMG_4077.jpg (is there suppose to be a O ring here?)
http://c.imagehost.org/0934/IMG_4083.jpg
http://c.imagehost.org/0069/IMG_4085.jpg
Old 08-17-2008, 08:58 AM   #14
Journeyman Plumber
You still should be able to reposition the handle where you want it. I was correct the first time this is not a single control faucet. That is an AM/STD stem.
Need help fixing leak to Delta Monitor 1400 series shower/tub faucet star987 Plumbing 16 05-01-2011 05:26 PM
Shower faucet problem PlainlyJane Plumbing 16 09-06-2009 07:43 AM
Toilet Seal Leak Problem boblgamble Plumbing 4 06-21-2008 10:42 AM
Toilet problem - Leak in Pipe underneath jackbean Plumbing 7 05-28-2008 10:33 PM
HVAC/Comfortmaker leak problem notsogoodwrench HVAC 8 08-09-2007 09:59 AM
