Faucet Handle Won't Come Off - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-19-2011, 03:35 PM   #1
faucet handle won't come off
I'm trying to fix a leaky sink faucet in my bathroom. No name or other identifying marks on it. The handle has a set screw on the side, which I can take off and then the handle will begin to slide up but it won't come off completely. It feels like its hitting a metal stop. There is no screw in the top of the handle. How do I get the handle off?
pkhalsa is offline   Reply With Quote
Old 06-19-2011, 04:09 PM   #2
There's usually more than one set screw. Did you get all of them?
Ishmael is offline   Reply With Quote
Old 06-19-2011, 04:15 PM   #3
Thanks for the suggestion Ishmael. However, it's not so much that the handle is stuck, but rather that it slides up the shaft and then hits a stop. It actually feels (and sounds) like the stop is metal. I'm wondering if there's something else, other than the set screw on the side, that I'm supposed to be removing.
There are 'Hot' and 'Cold' labels on the handles, which are held down by a ring that screws off. But there's nothing underneath them, like a cap that could be pried off hiding a screw.
Old 06-19-2011, 04:33 PM   #4
Can you post some pictures? Some faucet handles need to be unscrewed at the escutcheon beneath the handle. In other words, the escutcheon and the handle are really one unit that screws down over a knurled spline. Some Moen faucets are like that.
Old 06-19-2011, 04:48 PM   #5
Here's an image of the unit:
Old 06-19-2011, 07:04 PM   #6
It sort of looks like a Newport Brass faucet, but I don't think it is...
Are there any screws under the porcelain inserts ("hot" & "cold)?
Old 06-19-2011, 10:08 PM   #7
Not that I could find. The 'hot' & 'cold' porcelain pieces are held in place by rings (which screw on & off). Once the pieces are taken off, it appears to just be metal that is part of the handle itself.
I also looked to see if there were some sort of restraining pins, but I couldn't find them either.
Old 06-20-2011, 06:01 AM   #8
DIY staff
Rewards Points: 7,174
See if the bell shaped escutcheon below the handle will unscrew---the handle might be flared into the escutcheon.---Mike---
Old 06-20-2011, 06:11 AM   #9
Rewards Points: 1,578
Did you fully remove the set screw? If not, try that and see if it comes out.
bob22 is offline   Reply With Quote
Old 06-20-2011, 08:39 AM   #10
Thanks for the suggestions. I haven't yet attempted to unscrew the escutcheon, but once I do remove the set screw on the side, then the handle will slide up the tines such that it is completely free of the escutcheon.
Bob22: yes, I did completely remove the set screw. That allows the handle to move, but as the handle slides up the tines, then it appears to hit this 'stop' towards the top.
Problem removing handle off of Delta Monitor 1400 series tub/shower faucet kcinsj Plumbing 35 10-22-2015 04:02 PM
Broken Shower Faucet Handle DFT Plumbing 1 02-23-2011 08:55 AM
single handle or double handle faucet for bathroom aundav Remodeling 5 06-16-2010 04:56 PM
Faucet handle faces the wrong direction. diyntn Plumbing 1 04-22-2009 08:09 PM
deciphering faucet handle EdPDX Plumbing 1 11-05-2008 07:12 AM
