Old 11-14-2010, 09:45 AM   #1
Faucet handle repair
My Hot handle is leaking when I turn it on. I removed the plastic handle and collar and the outer stem extension. how do I get to the piece inside the pipe that the handle goes on. I guess I need to take it all to the store to get the right one to replace .But I don't know how to get it out. PleaseHELP. (This is a mobile home)
Thanks Margie
margiecw is offline   Reply With Quote
Old 11-14-2010, 10:24 AM   #2
Super Moderator
A picture would help---Usually there is a 'cap nut'--the shaft goes through a hole in the middle of the cap nut----If you remove the cap nut the shaft should unscrew--counter clock wise for the hot--
Under the cap nut will be some 'packing'--either a washer or a teflon string,wrapped around the shaft--
That is usually the cause of the leaking.
Problem removing handle off of Delta Monitor 1400 series tub/shower faucet kcinsj Plumbing 26 02-18-2012 10:23 AM
Two handle kitchen Faucet invisible screw: Leaking Faucet chicago7100 Plumbing 8 09-20-2010 09:24 AM
single handle or double handle faucet for bathroom aundav Remodeling 5 06-16-2010 05:56 PM
deciphering faucet handle EdPDX Plumbing 1 11-05-2008 08:12 AM
Repair outdoor faucet? mx13 Plumbing 3 04-09-2007 07:08 PM
