Faucet Handle Problems - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-27-2015, 01:52 PM   #1
Rewards Points: 6
Faucet handle problems
I've popped off the handle, removed the screw and plastic, and the small wire, but can't seem to get the actual stem out. I don't want to break it, but I can't seem to pull it out. Ideas anyone?
jdearie is offline   Reply With Quote
Old 12-27-2015, 02:09 PM   #2
Rewards Points: 1,952
Could you post a quick picture?
Is it Moen?
Ghostmaker is online now   Reply With Quote
Old 12-27-2015, 02:15 PM   #3
Rewards Points: 6
Sorry - I tried posting photos a few times... hope it takes this time. It's a Glacier Bay Leonardo faucet from Home Depot.
Old 12-27-2015, 02:28 PM   #4
Rewards Points: 282
Still looks like there is a retainer clip on it. Try some pentrating oil.
jmon is offline   Reply With Quote
Old 12-27-2015, 02:32 PM   #5
Rewards Points: 6
Thanks! Picture was taken before I removed the clip...
That's the only difference between the picture and how it's now. The stem is still in there very tight...
From all the YouTube videos I've seen, it should just pull out... But I must be missing something.
Old 12-27-2015, 03:25 PM   #6
Rewards Points: 6
side view if that helps... i've tried loosening it, but all i see to do is mark up the brass.
Old 12-27-2015, 03:43 PM   #7
Rewards Points: 282
Could just be sediment build-up. Try some penetrating oil and channel locks or pliers and work stem back & forth a little, then up. Is it threaded in? If so, use a cresent wrench.
As you've mentioned, stem should just pull right out once the locking nut and retainer are removed. Open stem to on position. Don't forget to turn off water.
Are you replacing the stem with a new one? If so, take it to a hardware, big box, or plumbing supply store and match it up. Don't forget to check the seats and springs, replace if needed.
Old 12-27-2015, 06:01 PM   #8
Rewards Points: 1,258
The hex nut looks to have had all the wrong wrenches on it so now it's time for the pipe wrench. Bump the pipe wrench with your hand as an impact and if that hurts too much a 2x4 about 2 ft. long makes a great impact tool when it hits near the handle end.
Old 12-27-2015, 06:35 PM   #9
Make sure the handle is in the open position. Then use channel locks on the big brass nut or an adjustable wrench. But it must be fully open first.
Old 12-27-2015, 07:40 PM   #10
Rewards Points: 13,724
You have a store brand cheap faucet, do yourself a favor and replace the whole thing with a better brand, Moen comes to mind.
Old 12-27-2015, 08:15 PM   #11
Rewards Points: 582
be careful not to hurt stem splines anymore.....remember righty tighty ..lefty loosey...
Old 12-28-2015, 08:51 AM   #12
DIY staff
Rewards Points: 7,174
Have you removed the cap nut yet? That shaft goes through the cap nut---put a crescent wrench on that and unscrew it
Problem removing handle off of Delta Monitor 1400 series tub/shower faucet kcinsj Plumbing 35 10-22-2015 04:02 PM
Leak from faucet handle Wench General DIY Discussions 4 09-16-2015 12:57 AM
Leaking Faucet: Single Handle Shower Head chicy724 Plumbing 27 03-03-2015 05:43 PM
Hot Faucet Handle too Tight doolenberg Plumbing 4 01-17-2015 03:07 AM
Shower faucet problems Dmaxmama Plumbing 1 11-27-2008 07:22 PM
