Old 05-20-2008, 09:03 AM   #1
Faucet Drain Lever Installation
I installed a new undermount sink and vanity top along wtih a new Moen faucet. I am having a hard time hooking up the pop lever used to open/close the drain plug. The sink is deeper than the original. The faucet has the lever for moving the drain up and down connected to a shaft that is perpendicular and mounted in the sinks drain tube.
The problem is the lever mounted inside the sink drain is too close to the drain pipe that is plumbed through the wall. There is not enough clearance for it to move up/down.
I can rotate the sink drain tube so this lever can freely move up/down, however the faucet lever can't connect. I also must mention the faucet lever is not straight up/down....it is inserted through the faucet on an angle. When I rotate the sink drain, it puts too much resistance on the sink lever and it won't move.
Any suggestions or ideas which I am overlooking?
DK75 is offline   Reply With Quote
Old 05-20-2008, 06:11 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Pictures would be helpful.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 05-21-2008, 11:04 AM   #3
I have attached a few pictures of my situation. The problem is two-fold in my opinion.
1. The stem lever comes in on an angle and not straight up and down.
2. There is not enough clearance between the horizontal pipe of the p-trap and the ball-type fitting where the sink drain fitting is positioned.
If you have any suggestions that I am overlooking that would be great. I am going to mess around with it tonight and maybe try to rotate the sink drain tube 90-degrees.
Faucet Drain Lever Installation-img095.jpg   Faucet Drain Lever Installation-img097.jpg
Old 05-21-2008, 11:08 AM   #4
Please note the metal strapping to connect the lever to the sink drain is bent. I already tried it straight when new and it didn't work. So I tried bending it to take some of the load off it when being pulled or pushed at an angle thinking it may be more free to move. Didn't help at all.
vessel sink drain and faucet Katmac Plumbing 17 10-11-2010 09:12 PM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 08:10 PM
drain installation GLASSMAN1 Plumbing 2 02-15-2008 08:05 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Hot Water Heater Drain Faucet handy man88 Plumbing 6 11-08-2007 11:22 AM
