-   -   Faucet baseplate leaking (http://www.diychatroom.com/f7/faucet-baseplate-leaking-148753/)
sippinjoes 06-30-2012 08:43 PM
1 Attachment(s)
I recently replace my kitchen faucet. The old baseplate leaked and now this one does too. I tried to use plumbers putty to increase my chances of it not leaking, but it is cracking and pulling away now. I tightened it as much as I could and the baseplate would not seat properly on the plastic 'seal'. Is there a trick to sealing these poorly designed baseplates? With as accomplished engineering we have these days, and even in the plumbing industry, the design seems pretty weak and leaves too much room for faulty installation. If I don't come up with something soon, I will end up removing the baseplate and plugging the two extra exposed holes. Is there anything I could use these holes for? Disposal switch?
joecaption 06-30-2012 08:49 PM
A bead of silicone under it will work. The trick is to not over tighten it, just snug it up at first. The next day tighten it up. That way you not squeeze out all the sealer.
