Fanornot? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-09-2010, 08:54 AM   #1
the Musigician
DangerMouse's Avatar
Fanornot?
If I have a window in my bathroom, is it required to still have a fan?
Thanks!
DM
Old 09-09-2010, 09:08 AM   #2
Not according to everything I have read
I still install one in every bathroom
Old 09-09-2010, 09:12 AM   #3
the Musigician
I HAD to put one in the old bathroom to pass elec. inspection years ago, but it had no window.....
I'm at that stage so I need to know if I have to plan on it or not. Personally, I don't like them, they're always too noisy and fail too often.
Of course, this has NOTHING to do with the fact they're all made in "you know where" now.......
DM
Old 09-09-2010, 09:20 AM   #4
fabrk8r
fabrk8r's Avatar
Have you ever considered a remote fan?
http://residential.fantech.net/resid...single-grille/
I've used Fantech products before and I believe they are made in North America for the most part. The last one I used was mfg. in Canada.
Broan/Nutone carries a line of remote fans also.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 09-09-2010, 09:22 AM   #5
We use the fans during the Spring-Fall
Not in the winter
For most of the summer I use a double fan in the bathroom window
Mostly at nite to exhaust hot air out, and pull cooler air in other windows
But I also use the window fan as thebathroom fan most of the summer
I installed a new fan/light last year
Its fairly quiet & has 2 bulbs for lights
Old 09-09-2010, 09:57 AM   #6
the Musigician
My main problem is putting another hole in my gable, roof, etc. and having to run exhaust tubes.
I really don't have the time for the extra project right now, so I need to know if the inspector will insist on one being installed as code or not?
Thanks!
DM
Old 09-09-2010, 10:06 AM   #7
HVAC / Plumbing
As far as the inspection, It all depends on what's required in your area. Here, if you have a window. you don't have to install a fart fan
kenmac is offline   Reply With Quote
Old 09-09-2010, 10:41 AM   #8
the Musigician
I just got the call back from the electric inspector, (nice guy!) He says no fan needed if windowed! Yay!
And he says I can run both bathrooms on one 20a circuit! Yay! (just the outlets, but that's fine since all my overhead lights are on their own circuit)
Po)
Color me happy today!
DM
Old 09-09-2010, 12:27 PM   #9
HVAC / Plumbing
I would say that those outlets will have to be GFCI
Old 09-09-2010, 12:54 PM   #10
the Musigician
Yup, the first one at least.
DM
Old 09-09-2010, 04:12 PM   #11
I would wire the 2nd bathroom from the LINE side of the power feed
Then install another GFCI in the 2nd bathroom
If one bathroom GFCI trips both will not be out
Old 09-09-2010, 04:27 PM   #12
the Musigician
Good idea, thanks!
DM
Old 09-10-2010, 02:14 PM   #13
Rewards Points: 352
In MI the last bath window I installed had to be safety glass
plumberinlaw is offline   Reply With Quote
Old 09-10-2010, 03:19 PM   #14
the Musigician
Hmmm, was it IN the shower/bathtub? I could understand that, but this one is in a wall far from the tub. I don't think he'll say anything, but if he does, I'll do whatever I have to...... *sigh*
DM
Old 09-10-2010, 06:14 PM   #15
Rewards Points: 352
DM
yes it was in the shower/tub
