Is It Fairly Easy To Sweat Copper If Never Done It Before? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-13-2013, 09:55 PM   #61
Originally Posted by TarheelTerp
If someone else is buying your acid brushes...
a wipe over the joint with a fluxy brush will make a nice blending job.
So the fitting can turn green from the flux or the flux brush getting burnt from the hot fitting. Then you but it in the flux for the next time and content the flux.
handyman21 is offline   Reply With Quote
Old 02-13-2013, 10:15 PM   #62
Plumber
TheEplumber's Avatar
Rewards Points: 682
Can you interpret this please?
Old 02-14-2013, 09:27 AM   #63
Not A Licensed Pro
"So the fitting can turn green from the flux or the flux brush getting burnt from the hot fitting. Then you but it in the flux for the next time and content the flux."
"So the fitting can turn green from the flux or the flux brush getting burnt from the hot fitting. When you PUT the brush back in the flux container, you've CONTAMINATED the flux for the next time you need it."
...Using the brush after heating the joint.... oxidized copper (green) and burned flux getting back into the container... vs only using the flux brush to brush flux on cool, clean copper
this will probably not be your last repair...
you can buy a bag of "plumber's bread" that contain several plugs of dissolving material (various sizes) that will give you a couple minutes of water blocking... AND THIS STUFF NEVER SPOILS
when you turn on the water, if you have a faucet down the line without an aerator (tub) open it up first to blow out your bread residue
kevinb70 is offline   Reply With Quote
does pex pipe sweat like copper? Arch Hill Plumbing 3 09-24-2011 09:36 PM
How to Rewire aluminum to copper wall outlet. deepseathomas Electrical 1 10-20-2010 02:11 PM
Copper look gutters but not as expensive ? Scuba_Dave Roofing/Siding 9 08-02-2010 09:23 AM
Is this possible and fairly easy to do? WingNut Electrical 15 07-05-2009 02:17 PM
Debate - Pex vs Copper sandy2982 Plumbing 13 04-10-2008 10:47 PM
