Is It Fairly Easy To Sweat Copper If Never Done It Before? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-30-2013, 11:44 AM   #16
Rewards Points: 736
Also make sure not to burn your house down. Sometimes it's easy to forget that the flame isn't just heating the pipe but also... shooting flame at what's behind / around it!
TheBobmanNH is offline   Reply With Quote
Old 01-30-2013, 11:54 AM   #17
DIY staff
Rewards Points: 7,174
Just a suggestion--If you haven't purchased a torch yet----buy one with a hose---
They are so much easier to use than the tank mounted ones----easier to get into tight spaces--no flame changes because the tank is tipped---good useable ones cost $40 or so----
Also --BoB Man made a good point---have plenty of scrap steel available as fire blocking/heat shields-----flat electric box covers work well---the ears allow you to temporaraly screw the plate in place---------
Old 01-30-2013, 01:56 PM   #18
Roofmaster
Rewards Points: 2,210
Metal is a conductor A piece of AB siding Stratolite or Transite works really well. Now called GAF Weatherlite.
No its not friable.
Old 01-30-2013, 02:11 PM   #19
Roofmaster
Why dont you just use CPVC and Flowguard gold primer and glue? I like soldering, but it does have a learning curve. Yes PEX is the latest and greatest thing, but something about crimped on fittings gives me the willies, but I guess it should'nt, as this technology has been used in Europe for years.
There is just something solid about L Copper.
Old 01-30-2013, 02:28 PM   #20
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
It's right against the cinder block so cutting may be tricky but wont have to worry about flammability. If I do this in copper it's just cutting a pipe and recapping it (it's already capped but it passes through a wall that I will be modifying) but anything new I add I go with pex and crimp fittings. I was kinda weary too about crimp fittings but they seem to be tested and true and none of the ones I made have leaked or let go yet. Hopefully never will. :P
Going to head to HD to buy some copper fittings and pipe to practice on first. I'll get a fitting that will fit on the faucet so I can pressurize it to test. I might try to make something useful like a radiator or something. If I can do all those elbows without leaks then I should be good.
Red Squirrel is online now   Reply With Quote
Old 01-30-2013, 02:39 PM   #21
Rewards Points: 672
I sweat as much as I can out in the garage, even trying to get angled pieces just right.
I don't believe even a half assed sweat job will burst if it isn't leaking to start with.
B
Beepster is offline   Reply With Quote
Old 01-30-2013, 03:45 PM   #22
Roofmaster
If there is water in that cinder block it can explode in your face if you hit it with a torch, grasshopper.
Kind of like a Hand Grenade. Use CPVC, or Pex. Much better for rookies, You can fix PEX wet, and no waiting for glue to dry. Just make sure you read up on it, fully engage your fittings, and use US made crimp rings. Im sure even that market has been invaded, as I hear of out of round ones.
Any Suggestions from the pros here? Nibco?
Hint: Pex Supply Online.
Old 01-30-2013, 04:45 PM   #23
concretemasonry's Avatar
Rewards Points: 2,608
The white bread is a great way to eliminate the minor drips that can cause problems. Stuff it in and solder soon. Do not use the kind of bread your wife may buy (coarse ground all grain) since it takes for than a minute to flush through cleanly.
I was once afraid to sweat a joint, but now I look for an excuse to do one and then make the job look perfect with the the cosmetic wiping.
Dick
concretemasonry is online now   Reply With Quote
Old 01-30-2013, 05:43 PM   #24
So what you are saying if you have a spot the copper is bad. Cut it out and install pex or CPVC there. Well that fine but if it a old house the water line are the ground. Now you won't have a good ground. You must put a ground wire from one side of the copper to the other side of the copper. Or you must install grounding rod.
handyman21 is offline   Reply With Quote
Old 01-30-2013, 06:19 PM   #25
Wire Chewer
Rewards Points: 126
I do have a pex crimper/rings and done some pex before so I'm fairly comfortable with it and so far none of my work has let go or leaked. Anything new I add is pex, but to make such a simple change as to put a cap to a setup that is all copper it makes more sense to just learn to do it properly.
Good to know about the exploding cinder blocks. That spot did leak before I got the outside seal and weeping tiles redone, so there is the potential that there is water, though it probably would have drained by now. Is there a good indicator as to if there's water in there? Though, how long do I normally have to heat a fitting? It's not like I'm holding the torch there more than like 30 seconds right? Especially a cap I imagine it will warm up faster.
I just finished hauling 170 2x4's and 120 dricore tiles in the house so I'm too pooped to go anywhere, and can't because there's still another pallet in front of my car. So the practice session will wait till tomorrow.
Once I feel really comfortable then I'll do the pressure gauge (which I ordered) and I'll find a pressure reducer as well so I can lower my water pressure, which should help with previous issues I had such as getting a 1/4 pressure fitting to not leak.
Old 01-30-2013, 06:55 PM   #26
DIY staff
I never timed it but 30 to 45 seconds sounds about right--I use MAP gas which is a bit hotter than propane---sure wish the old MAPP was available--the was considerable hotter.
Old 01-30-2013, 07:23 PM   #27
Rewards Points: 338
+1 on that, for sure. not only that but trying to hold it upside down or at an angle in an awkward spot is tough on the ol' arm.
NitroNate is offline   Reply With Quote
Old 01-31-2013, 03:06 AM   #28
If all you need to do is cap an already capped copper line a little further back then just turn off the water, cut the pipe, then pop on a $6 sharkbite brass end cap. No fuss, no sweat (pun intended), no hand grenades....
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
profcolli is offline   Reply With Quote
Old 01-31-2013, 12:32 PM   #29
Something not mentioned yet is to wear some wraparound goggles. Hot flux tends to bubble and drip where you least expect it.
winnabago is offline   Reply With Quote
Old 01-31-2013, 03:19 PM   #30
Rewards Points: 610
BTW..NPT means National Pipe Thread..which is what most standard fittings have.
techpappy is offline   Reply With Quote
The Following User Says Thank You to techpappy For This Useful Post:
BigJim (01-31-2013)
does pex pipe sweat like copper? Arch Hill Plumbing 3 09-24-2011 09:36 PM
How to Rewire aluminum to copper wall outlet. deepseathomas Electrical 1 10-20-2010 02:11 PM
Copper look gutters but not as expensive ? Scuba_Dave Roofing/Siding 9 08-02-2010 09:23 AM
Is this possible and fairly easy to do? WingNut Electrical 15 07-05-2009 02:17 PM
Debate - Pex vs Copper sandy2982 Plumbing 13 04-10-2008 10:47 PM
