Failing PRV On One-inch Residential Service Line. - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-18-2011, 12:36 PM   #1
Failing PRV on one-inch residential service line.
When a PRV is failing do pipes rattle and do you get rapid fluctuations in pressure periodically?
ghartwell is offline   Reply With Quote
Old 11-18-2011, 02:27 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 542
Get a pressure gauge that will screw on to a hose bib or laundry sink and take some readings. Should tell you if you have PRV issues
Moving service panel away from main service line entry k2000lbs Electrical 3 11-28-2011 08:39 AM
Gas line for pool heater BillyDIY Plumbing 3 06-10-2011 02:29 PM
DIY Comedy--PVC for main water line? Daulton Plumbing 8 03-23-2011 09:03 AM
2x100a sub on service main jambud Electrical 17 03-12-2008 09:31 AM
Service size pipe 3/4 or 1 inch? kgphoto Plumbing 6 01-29-2008 06:23 PM
