Fabricate A Trap Instead Of Buying A P-Trap - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-02-2012, 05:02 PM   #1
Rewards Points: 1,492
Fabricate a Trap Instead of Buying a P-Trap
I have run into an unusual situation. The tenant complained about a slow kitchen sink drain. Upon examination we found that the drain pipe from the trap to where it goes into the wall was sloping uphill.
The standard P-trap when installed would not permit a better pitch.
Would it be practical to fabricate a trip using pieces of pipe so as to get a "trap outlet" higher up and then the pipe going to the drain in the wall would be pitched better?
The alternative would be to cut open the wall and make changes to the vertical drain pipe inside, putting in a tee closer to floor level so the pipe from the sink will be pitched better.
Old 09-02-2012, 05:07 PM   #2
Rewards Points: 13,444
Just cut the tail piece shorter.
You need a reguler trap so it can be taken apart to clean it out.
What in the world is that pipe with a cap on it suppost to be for?
Lowes and Home Depot sell a special cutter just for this job. There so thin that often they crack. It works better then a reguler pipe cutter or a hack saw.
Old 09-02-2012, 06:38 PM   #3
(The tee and cap at the bottom are a cleanout.)
Old 09-02-2012, 07:04 PM   #4
It's useless get rid of it. The trap when removed becomes your clean out access.
Old 09-02-2012, 07:33 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 542
I believe the maximum trap seal depth for a trap is 4" If you can build one within this dimension and get grade on the trap arm- go for it. Yes its nice to have unions, but not required.
Old 09-05-2012, 07:23 AM   #6
I inspected the drain more closely and it looks as if a regular P-trap will work. I'll use the idea of cutting the sink tailpiece shorter so the trap is higher up. Thanks.
The Following User Says Thank You to AllanJ For This Useful Post:
TheEplumber (09-05-2012)
Old 09-05-2012, 09:32 AM   #7
biggles's Avatar
ace that short piece into the straight to the wall thenuse a street elbow(if they have a PVC street) elbow into elbow going out after the trap
Old 09-06-2012, 01:17 PM   #8
I store dog food and toys under my kitchen sink and my p-trap gets banged around quite a bit.
Since I could not find a sturdy p-trap (all were thin translucent plastic types) so I ended up making one myself using PVC.
The entire assembly up to the stub (arrow) can be removed for cleaning, if necessary.
allthumbsdiy is offline   Reply With Quote
Old 09-06-2012, 08:08 PM   #9
Doing it myself
Alan's Avatar
Rewards Points: 2,086
That actually looks like it worked out pretty well, but it's still only as sturdy as the slip joint connection you have to the tailpiece IMHO.
I've had customers ask for something similar to that before, and I just wonder : wouldn't it be a little easier to just be careful?
Journeyman Plumber
Old 09-06-2012, 08:29 PM   #10
Yes, slip joint is the weakest point, but everything before that is far more sturdy than the kits I checked out.
Being careful sounds perfect, except I have energetic 5 and 3 year olds, all fighting each other to grab the food container to feed the dog!
I swear, my dog sees this and runs away, even if she is hungry
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
Connecting brass trap to cast iron (Noob) acr2001 Plumbing 7 08-22-2012 12:37 AM
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 07:59 PM
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 12:39 PM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 10:10 AM
