Extra High Vent Pipes? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-09-2008, 03:59 PM   #1
Extra high vent pipes?
Hi;
I was walking past a large, new home in town and couldn't help but notice the two pipes sticking up from the roof.
Each pipe was an extension of the normal vent pipe, and was about 10 feet high.
Each had a standard rain cover fitted to the top.
I am curious as to why the vent pipes need to be extended.
The only thing I can think of is that this house has a bathroom or other plumbing on the uppermost floor and the vent pipes need to extend a minimum height above these fixtures.
Any other ideas?
It looks really odd.
FW
fw2007 is offline   Reply With Quote
Old 07-09-2008, 05:06 PM   #2
Registered User
Termite's Avatar
Is it a flat roof, perhaps a party deck of some sort? If so, the vents must rise 7' above the walking surface.
Otherwise you're just trying to clear the design snowfall accumulation in the area.
Old 07-09-2008, 06:49 PM   #3
It's not a flat roof. As far as snowfall, here in NJ, we rarely get more than 1 foot in a storm.
I would be kind of leary of having anything like that sticking up from my roof. For one thing, these things might act as lightning rods, and when lightning did hit it could electrify the entire drain system.
Another issue might be high winds.
FW
Old 07-10-2008, 09:44 AM   #4
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
The only other reason for extended vents would be if they were too close to an adjacent window or door. Most plumbers, however, would just relocate the vent instead of sticking them up that high.
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Old 07-10-2008, 12:08 PM   #5
Rewards Points: 1,910
If they have a rain cover then they aren't vents for the DWV system. Most likely vents for high efficiency condensing gas devices such as furnace or water heater. No idea why they'd be so tall. Maybe they are gas fireplace vents and the local inspector is considering them to be chimneys and have to meet chimney height requirements. Stranger things have happened.
Old 07-10-2008, 01:36 PM   #6
I agree with jogr, that they are not plumbing vent pipes. My Sister had a new furnace installed and it had "mufflers" installed in the exhaust piping and it was still loud. The height could have been to lessen the noise inside the house and for the neighbors comfort.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 07-11-2008, 09:07 AM   #7
They sure looked like they were extensions of the vent pipes coming out of the roof.
I'll try to get some photos.
FW
finishing a basement bath - tie in to ejector pump vent? ajbowman Plumbing 7 04-15-2008 01:09 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 07:34 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
