Old 08-11-2005, 06:16 AM   #1
External Waste Water Drain
Hi-
Has anyone ever had experience/confirmation that it's ok to do straight vertical drop (of about 10inches) for waste water (bath/sink) bossed into a w.c (angled) waste feed pipe - which itself feeds into the main soil stack? My concern is that all waste should be correctly angled to avoid "water rushing, solids remaining" and you never see vertical runs of any pipes into soil pipes anywhere, whether feed or main stack....
TL
alangan is offline   Reply With Quote
Old 08-11-2005, 08:42 AM   #2
Vertical drops are fine, it is a good thing or none of us would have plumbing above the first floor. Water and solids will fall together it is on the horizontal pipes when pitch becomes a concern and that should be at 1/4" per foot.
plumguy is offline   Reply With Quote
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 04:28 PM
Main Water Drain KJohnson Plumbing 1 01-29-2007 07:21 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
Water heater drain valve leak Fletcher33584 Plumbing 3 02-28-2006 08:07 PM
