External (to Wall) Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-01-2009, 04:04 PM   #1
External (to wall) plumbing
My house is made of solid concrete block walls (think abobe brick house - only with concrete instead of mud and straw). The plumbing fixtures are poured into the walls (about nine inches thick). I kid you not. I can't find any shower and bath fixtures designed to be installed ON the exterior of the wall (as opposed to INSIDE the wall).
This may sound wierd but its the only viable alternative. Help appreciated
Calron is offline   Reply With Quote
Old 04-01-2009, 05:07 PM   #2
Sounds weird. How did it pass inspection?
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 04-01-2009, 06:25 PM   #3
Remodeling Contractor
Use fixtures designed for a claw foot tub. Run the pluming exposed with chrome plated pipe and tubing. Similar to a fancy outside shower one would do at a spa.
Old 04-07-2009, 01:29 AM   #4
Outside wall plumbing
Thanks, but the problem is not piping, but faucets. Can't find any faucets don't look like crap. Only standard in-line shut off valves. Looks like plumbing, not fixtures. Looking for suppliers for upscale outdoor showers. Can't find any.
Old 04-07-2009, 07:11 AM   #5
Rewards Points: 156
fake wall
You could always build out from the wall a little bit. That would hide the shower mixer valve at least.
jayp is offline   Reply With Quote
Tags
plumbing , solid wall
~HELP~ Basement Wall is bowing earthad1 Building & Construction 6 06-05-2008 12:24 PM
Need to re-route plumbing in kitchen - advice needed capslock Plumbing 1 04-03-2008 03:22 PM
Wall to ceiling fw2007 Electrical 4 03-31-2008 06:18 PM
Ant's through slab plumbing aace Pest Control 4 02-13-2008 03:48 PM
Low Retaining Wall cibula11 Landscaping & Lawn Care 3 07-29-2007 12:02 AM
