External Lint Filter ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-12-2007, 02:16 PM   #1
Greetings--
Its that time again-- the washing machine drain is clogged *sigh* This seems to happen about once a year or so. The main drain it connects to runs fine.
My old washing machine had a lint filter. I had to clean it out now and then but at least the drain wouldn't stop up. New machines apparently dont have such a device, so all the lint goes into the drain.
I asked both an appliance repair guy and the plumber about an esternal lint fliter or trap. Neither had heard of such. Surely, someone has one of these-- a filter to hang on a wall and run the washer drain through ???
Piney is offline   Reply With Quote
Old 04-12-2007, 02:39 PM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Is it directly plumed or using a discharge hose?
If using a hose there are sock type things that attache to the end of the hose with a hose clamp.
I did a google search for you and found the following
http://www.laundry-alternative.com/septic-protector.htm
http://www.asktooltalk.com/home/qand...lint-traps.htm
http://www.asktooltalk.com/cgi-local...s/aquarian.htm
http://www.repairclinic.com/0081.asp?RccPartID=541811
May also want to try and make your own with a small mesh bag and a hose clamp. Just check it frequently to make sure it doesn't over fill.
Brik is offline   Reply With Quote
Old 04-12-2007, 02:57 PM   #3
Its a hose type of connection that runs into a drain in the wall.
Thanks for the links- a couple of them look promising.
Old 04-12-2007, 03:08 PM   #4
Handyguy
Brik's Avatar
FYI, inside of the wall likely looks something like this
Old 11-10-2009, 08:57 AM   #5
External filter.
Great job in finding the external filters. I have also been looking to keep the lint out of my drains.
What I am still wondering though is why the manufacturers ever stopped putting lint filters inside the machine. They were just a simple device that was easy to clean. They kept the lint from getting into the pump which extends its life. I am on my 3rd and last pump on my top loader now. The pumps when examined are always full of lint. It seems to me they removed the lint filters to drive up the repair costs.
Handyoldguy is offline   Reply With Quote
Changing filter in Whirlpool whole house water filter farnamct Plumbing 7 12-20-2012 09:11 PM
filter in concord 80 plus furnace hyyx632 HVAC 5 12-12-2008 10:21 PM
External Lint Filter for Washing Machine ? Piney Appliances 2 05-03-2007 11:28 AM
Faucet options for undercounter water filter mdr25 Plumbing 4 03-02-2007 04:56 PM
