Exterior Sump Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-17-2011, 09:47 PM   #1
Exterior sump pump
We need to put in an exterior sump, as a sump had to go in where a bedroom is located and it's keeping our son awake! We were going to put in an exterior pump just a little lower than the one inside but not sure how? We were thinking of a culvert surrounded by gravel.
boulder58 is offline   Reply With Quote
Old 05-18-2011, 06:17 AM   #2
DIY staff
Rewards Points: 7,174
Where are you located? If it freezes where you live---this may be a bad plan.
Old 05-18-2011, 07:47 AM   #3
Rewards Points: 1,536
An outdoor sump pump pit may very well work out nicely. Some features would be:
1. The water turn on level is more than 3 feet below the surface.
2. You have a cover to which is attached a thick blanket of insulation.
3. The portion of the pit between pump turn on and turn off levels is quite large, say, 25 gallons or more,
4. There is no check valve (the disadvantages are overcome by #3)
5. The outlet hose or pipe rises straight out of the pit, makes a bend, and then is continuously sloping down to the end where the water is released.
If the pit can't be 3 feet deep, add a forced air duct from the house that sacrifices inside air to the pit. Also a not quite airtight cover that is insulated and extends beyond the pit a foot or two on all sides (to insulate the adjacent ground surface). A fan could be thermostatically controlled to turn on when the pit temperature goes below 40 degrees.
Properly installed, an outdoor sump is ideal for an outside perimeter drain system.
Prior to installing the new outdoor pit, your son may sleep better with a speakered radio left on.
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Sump pump operation MikeKy55 Plumbing 16 05-11-2011 04:35 PM
Low Well Pressure, Submersible Well Pump, Help Please! tpolk Plumbing 7 11-13-2009 06:13 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
