Extension For Cleanout - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-22-2010, 04:33 PM   #1
Extension for cleanout
I have a 4" cast iron cleanout wye. It is in an inaccessible area right now. It is just out of reach around a corner. Inspector said it was ok to attach an extension to the accessible side of the corner.
How do I connect plastic to the cast iron wye? Is there a threaded ABS (or PVC) pipe I can thread onto where the cast iron cap was, and then attach a plastic cleanout plug there?
acerunner is offline   Reply With Quote
Old 10-22-2010, 04:50 PM   #2
Is the old clean-out held in with lead and oakum, or is it held onto the wye with a no-hub clamp?
The answer can complicate things. If it's no-hub, then you can simply remove the end clean-out and attach your PVC with a 4" PVC to No-Hub adaptor with the same clamp. If it's a poured lead joint, then the inspector will probably expect you to melt the existing end clean-out out of the joint, and pipe from there beginning with a PVC "manoff" fitting held into the wye by a newly poured lead joint. At least that's what would be required here in MA - check your local codes. Here in MA, you can't take out just the plug and screw in a male adaptor and go from there.
Ishmael is offline   Reply With Quote
Old 10-23-2010, 01:39 AM   #3
I don't know about the lead and oakum.
this is what it looks like.
Old 10-23-2010, 06:03 AM   #4
Yeah, you have "service weight" cast iron pipe and fittings (aka - "bell & spigot"). Check out this diagram:
http://chestofbooks.com/home-improve...-Joint-485.jpg
Oakum is sort of a waxy/oily, fibrous material that gets packed into the hub (bell) of the fitting around the straight end (spigot) of the next fitting or length of pipe. It helps to make the joint water-tight as it tends to swell a little after it gets wet, but it also serves to keep the lead from spilling right past the joint when it's poured.
In any case, check with the inspector and see if he'll allow you to simply remove the clean-out plug, leaving the female fitting in place, and adapt to it with a 4" PVC male adaptor. As I said...that's not allowed here in MA, but it may be in CA.
If he says no, ask if you can use a service weight gasket (after removing the old lead and fitting). The gasket takes the place of a new lead joint.
The Following User Says Thank You to Ishmael For This Useful Post:
acerunner (10-23-2010)
Old 10-23-2010, 12:23 PM   #5
I will have to asks after the weekend. Although if you are right, I would be worried about using the lead and oakum. Never done it before. How do you melt the lead? Will a standard propane torch be able to melt lead?
Is this the gasket you're talking about?
http://www.fernco.com/plumbing/donuts-o-rings/donuts
Old 10-23-2010, 12:28 PM   #6
yea thats what he was talking about. getting the lead and oakum out of the existing joint is a PITA. You'll be melting and scraping lead for awhile to get it all out. I would cut out the cleanout and install pvc/abs with nohubs to connect back to the cast, or just screw in a mip. may not be code, but is it that important? No water will flow thru it, and it won't break if you properly strap it in
the_man is offline   Reply With Quote
Old 10-23-2010, 01:28 PM   #7
it IS important because I am doing permitted work, so there will be an inspection. Also, the pipe for the cleanout is a short ~1" stubby as you can see in the picture so there isn't much area for the clamp to hold.
Old 10-23-2010, 02:33 PM   #8
Just reread the post, didn't see the part about the inspector before. If he ok'ed an extension, ask him if its ok to thread in ABS to the cleanout adapter. If you have to pull the fitting, get a good mapp torch and a small chisel. Heat, scrape, repeat I've never poured lead, but i think it had to be 1" thick so it'll be thick. have fun
Old 10-23-2010, 07:56 PM   #9
The threads for that clean-out will not be 4" they will be 3 1/2" you need to get that entire clean-out fitting out of the hub and redo it with either lead and okum or service weight gaskets.
SuperPlumberGuy is offline   Reply With Quote
The Following User Says Thank You to SuperPlumberGuy For This Useful Post:
braindead (10-24-2010)
Garage Door Extension Spring Question kmc143 Building & Construction 4 02-23-2010 08:24 AM
I can't find 16 gauge heavy duty extension cord! darsunt Electrical 21 08-04-2009 07:50 PM
help re-installing shower head 1/2" pipe extension cbons Plumbing 2 04-15-2009 05:06 PM
Extension Cord Safety Ultrarunner2017 Electrical 23 01-20-2009 09:11 PM
Air Compressor stopped working, extension cord was used. dawho1 Tools 3 10-07-2008 05:14 AM
