Expansion Tanks Questions - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-01-2007, 10:33 AM   #1
I bought one of those potable water expansion tanks that goes near the water heater. I was surprised that it had an adjustable pressure with a tire pump valve. (I was required to buy it by code of coarse)
OK - seriously, does a plumber actually check the exact water pressure first and then actually adjust the tank pressure. OR - do they just screw it on as it came from the box and forget about it?
I just can't imagine anyone would actually take the time?
What about leaks - will they add a 2nd drip pan to the code just in case this thing leaks? Or a giant $50 pan that can catch drips from both units? MAN - more and more code mandated gadgets that add to cost, complications and future problems...............
wannabuild is offline   Reply With Quote
Old 02-01-2007, 10:58 AM   #2
jproffer's Avatar
Rewards Points: 702
The bladder pressure is to control the pressure switch, which runs your well ( I assume you are on a well). It has nothing to do with incoming pressure.
EDIT: OK, it does have to do with incoming (from the well) pressure. It has nothing to do with outgoing (from the tank to the house) pressure.
jproffer is offline   Reply With Quote
Old 02-01-2007, 11:58 AM   #3
Sorry - I wasn't clear enough
This is on a municipal piped system with streetside water meters.
The tank is a small (2gal?) that just attaches to a "t" fitting just before cold enters water heater.
It is required (I beleive) because newer water meters have a backflow preventer and supposedly pressure from water heating can build up and cause havok. In other words "WATTS regulator co." came up with a $30 code mandated item that you are required to buy! (I digress)
Nothing to do with well water systems.
Old 02-01-2007, 03:14 PM   #4
Journeyman Plumber
Ron The Plumber's Avatar
Yes a plumber will test the pressure on the house and adjust pressure on the expansion tank.
2nd question, no 2nd pan I know of, usally one pan for heter is all that is needed.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Aluminum-wired house, questions LMH Electrical 2 05-24-2009 04:06 AM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
tiling questions - in middle of install mwill Flooring 8 12-11-2007 06:06 PM
Expansion Joints mpt1123@adelphia.net Flooring 4 03-09-2006 06:44 AM
