Expansion Tanks And Pvc - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-13-2013, 06:35 PM   #16
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,850
Originally Posted by Ghostmaker View Post
An Expansion tank is sized by the water heater. Depending on that you should purchase an expansion tank .. Up to 50 gallon HWT an ST-5 expansion tank will work. http://www.amtrol.com/media/document...t_Brochure.pdf
The link above will explain.
Also an Expansion tank can be located anywhere on the cold water. According to the IPC. Some inspectors are into the picture by manufacture of it over the tank but I have had no problems as long as it is on the cold and not valved off.
Ghost...that's fine... but Ben referred to upsizing not in reference to the tank size, but in reference to 100 ft run in the supply between main house and outlying WH.
Just wondering about his thought in that regard.
Peter
MTN REMODEL LLC is online now   Reply With Quote
Old 05-13-2013, 06:42 PM   #17
Rewards Points: 1,954
The run from the house to the hot water tank has nothing to do with expansion. Only the water heater is causing it. Thus only the water heater size determines the expansion tank size.
Old 05-13-2013, 06:50 PM   #18
Originally Posted by ben's plumbing View Post
I also agree with eplumber except...when we get around that 100 foot mark I reccommend going up 1 size in expansion tank..ben sr
Originally Posted by MTN REMODEL LLC View Post
Ben... could you explain.... just more room (water) for thermal expansion?
Ghost..... I'm not picking a fight here,... I agree with ya.... but Ben is a very smart plumber, and I was interested in his thought.
See above
Best
Peter
Old 05-13-2013, 07:04 PM   #19
Im just a dumb ass plumbing inspector and master plumber. So I'm sorry for trying to help.
Old 05-13-2013, 07:13 PM   #20
No you're not.... I'll bet we're both interested in what Ben was trying to say..... and thanks for your thoughts as they were mine also.... I thought I was the DA because I did not understand what Ben was saying....
Best
Peter
Old 05-13-2013, 07:34 PM   #21
Rewards Points: 582
your right ..heater determines size of expanison...as a safety allowing more room for expanison over that distance won't hurt......ben sr.....
Old 05-13-2013, 07:37 PM   #22
Plumber
TheEplumber's Avatar
Rewards Points: 678
Oh man-- I thought this was going get entertaining, I was heading for my pop corn
Old 05-13-2013, 07:39 PM   #23
Rewards Points: 582
me too...hope everyone chills ben sr
Old 05-13-2013, 07:44 PM   #24
Naah.... We all space out once in a while.... but if Idaho had a football team... we could get into it.
Peter
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
ben's plumbing (05-13-2013)
Old 05-13-2013, 07:47 PM   #25
No problem at all... just momentarily confuesed ...much like my typing
Best
Peter
Old 05-13-2013, 07:56 PM   #26
Rewards Points: 582
Best
Peter
no your not confused ..us old guys like to add sh@!@it to things ..just because we can...no really we had front house and back house with expansion tanks in front house distance between 90' tpr valve in back heater was weeping all the time changed smaller expanison tank to bigger one ..problem solved...
Old 05-13-2013, 08:08 PM   #27
Experience counts alot
Old 05-13-2013, 08:11 PM   #28
Plumber
Rewards Points: 678
It's called upcharge
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (05-13-2013), MTN REMODEL LLC (05-13-2013)
Old 05-13-2013, 09:51 PM   #29
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Originally Posted by jackwashere View Post
No I don't mean leaking water. It is doing it's job. When pressure rises above 100 psi the relief valve let's water out.
You said pressure reduction valve. Those don't leak water out. They do have bypasses, but you wouldn't know it was happening.
Journeyman Plumber
Old 05-13-2013, 10:02 PM   #30
**** happens. Had a very bad day busted a contractor on commercial work without a permit or a plan review. State may remove him of his contractors license. They do not like this on commercial work at all.
The Following User Says Thank You to Ghostmaker For This Useful Post:
ben's plumbing (05-14-2013)
