Expansion Tank For Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-05-2011, 01:53 PM   #1
Rewards Points: 1,062
Question
expansion tank for water heater
uhmmm... where do i put the expansion tank for my water heater, cold inlet pipe or hot pipe out?
Old 11-06-2011, 07:17 AM   #2
Rewards Points: 1,216
Anywhere in the cold water supply, even back where the main enters the house. I assume your relief valve on the Water Heater is weeping. Just get a small 2 gallon x tank and tee it into the cold water anywhere that's convenient for you.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
amakarevic (11-06-2011)
Old 11-06-2011, 07:37 AM   #3
Rewards Points: 1,500
Preferably right at the heater:
1. There should be no valve between the expansion tank and the water heater.
2. So someone looking at the water heater can easily see that "it has" an expansion tank.
The Following User Says Thank You to AllanJ For This Useful Post:
Old 11-06-2011, 08:04 AM   #4
Not necessary right at the heater. Put it where it's convenient to you to get at. Yes no valves between it and the water heater that would defeat the purpose of the x tank.
replacing hot/cold water lines ontop of hot water heater tank rickwest59 Plumbing 10 10-11-2011 08:09 PM
Expansion tank location?? rcassidy HVAC 4 10-06-2009 09:01 AM
Hydronic expansion tank mounting Joe F HVAC 3 09-28-2009 04:17 PM
Hydronic expansion tank Joe F HVAC 4 09-07-2009 04:48 PM
Insane water pressure in shower!!! Sarah24 Plumbing 5 12-09-2008 05:27 AM
