Expansion Tank For Tankless Water Heater?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-23-2009, 06:37 PM   #1
Rewards Points: 150
Expansion Tank for Tankless Water Heater??
I am in the middle of a new tankless install, and want to be sure of one thing... is an expansion tank needed? I never had one on my tank based system, and never had issues.
I understand the basis behind requiring it with a storage based system, where the heating of the water creates pressure within the closed system. But there is no storage within a tankless system.
Input appreciated.
TJ
TJ_in_IL is offline   Reply With Quote
Old 11-24-2009, 09:54 AM   #2
philcjr's Avatar
I just installed a tankless heater and I did purchase a service valve set which included a relief valve for the hot water side.
Maybe you can see it in the lower left of this pic.
philcjr is offline   Reply With Quote
Old 11-24-2009, 09:59 AM   #3
Rewards Points: 150
I have a similar set that I installed, which includes the T&P valve, my question was about an external expansion tank.
Old 12-05-2009, 12:47 PM   #4
Rewards Points: 150
If you never had one on your old system than i would think one is not needed for the tankless.Generally,exp.tanks are needed when a back flow preventer or PRV with internal check are installed on the water line to the house.
rudolph58 is offline   Reply With Quote
Sealed Combustion Furnace and Tank Hot Water Heater Yippee HVAC 6 06-16-2009 12:32 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Installing a Tankless Water Heater infoiam Plumbing 4 11-10-2008 09:59 PM
Water heater "leak"? TCinKC Plumbing 1 09-25-2008 12:01 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
