Expansion Tank Position - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-12-2011, 02:28 AM   #1
Rewards Points: 1,062
Question
expansion tank position
is it better to have an expansion tank right side up or upside down? or does it even matter.
i've seen them both ways
Old 10-12-2011, 06:36 AM   #2
Mark Potter's Avatar
Rewards Points: 150
As long as the drain valve is in position to drain the tank.
Mark Potter is offline   Reply With Quote
Old 10-12-2011, 07:47 AM   #3
DIY staff
Rewards Points: 7,174
Most small expansion tanks have no drain--only an air valve for the bladder--so it makes no difference with that type---
The old style big ones with a drain need to have the drain down ,obviously.
Old 10-12-2011, 10:06 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Agreed that it does not matter. Two things to consider. Installing it in the upright position will require less fittings. If you install it in the upside down position, you'll have less water dumping out when you remove it, but it will take more fittings and you'll likely have to do more work to support the thing.
I prefer installing them upright directly on top of the cold inlet.
Journeyman Plumber
Old 10-12-2011, 12:10 PM   #5
how so? i thought it takes a tee and a female adapter either way.
Old 10-12-2011, 01:49 PM   #6
I like them above the fitting so that any debris or particulate matter circulating in the system doesn't collect in the expansion tank.
Bob999 is offline   Reply With Quote
Old 10-12-2011, 02:12 PM   #7
Rewards Points: 1,418
Bladderless expansion tanks must be installed above the pipe. Tanks with bladders (diaphragms) can be installed in any position.
Tags
expansion tank
Expansion Tank handy man88 Plumbing 5 05-11-2011 09:00 PM
Installing an expansion tank Homerepairguy Plumbing 1 01-25-2011 09:10 AM
Is a Hot Water Expansion Tank required Needagameplan Plumbing 9 04-27-2010 04:09 PM
Installing a new boiler expansion tank CoachDad HVAC 0 01-06-2010 02:12 PM
Pressure relief leaking and expansion tank full themow HVAC 1 11-25-2009 05:49 PM
